Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 25th September 2012, 11:49 AM   #1061
qusp is offline qusp  Australia
qusp's Avatar
aha nope that was a mistake, can you send the second one back? I just grabbed the baggies I guess I forgot I hadnt taken mine out. what do you have there exactly? you mean 2 x 49 right? because I took my 45MHz one out and have that here in front of me, but dont have the 49.xx
AR2, you want a larger one than the ones Ian sent, because his break after a little while as they are too tight
Old 25th September 2012, 12:01 PM   #1062
PET240 is offline PET240  Australia
Can check in zee mornink. No worries to send back, dang thought I'd scored then......
Bugger darn crikey!
Old 25th September 2012, 10:14 PM   #1063
glt is offline glt  United States
Originally Posted by AR2 View Post
Wow...Thank you guys. Just one small question and two pages of ideas. You guys are awesome. Here is what I found. First I was thinking about some rubber seals for plumbing, than I remembered this place that I use for screws and bolts when needed, They have everything. Official title to search for - O Rings:
McMaster-Carr
What would really help is if anyone has original Ian's rubber rings, to share aprox diameter. Ether ID or OD would work.
Home Depot is a good source (the plumbing aisle)
www.hifiduino.wordpress.com
Old 25th September 2012, 11:21 PM   #1064
necplusultra is offline necplusultra  Canada
homemade silicon tubing and o-ring:
Homemade silicone O-rings and tubing
Old 25th September 2012, 11:28 PM   #1065
qusp's Avatar
hehe umm I think this method might be a little tricky at this tiny scale lol
Old 26th September 2012, 12:35 AM   #1066
hochopeper is offline hochopeper  Australia
And your dac build was a walk in the park? Not all Good ThingsTM are meant to be easy :P
Old 26th September 2012, 12:45 AM   #1067
Aren't we supposed to be at work......;-)
Old 26th September 2012, 12:55 AM   #1068
qusp's Avatar
I am at work lol
Old 26th September 2012, 02:02 AM   #1069
No need to skite...... :-)
Old 26th September 2012, 07:25 AM   #1070
marce is offline marce  United Kingdom
Toolstation > Plumbing > Washers & Fixings > O Ring Pack 85pc
Cheaper than making your own, and less fraught with problems, cool though.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
