Hifimediy direct out cs4398 DAC - Page 35 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th March 2013, 08:05 AM   #341
Oh No! This was on my list of builds I wanted to try!
Old 20th March 2013, 09:32 AM   #342
Default good news...
Seems they will be available again...
Old 20th March 2013, 08:38 PM   #343
Yes, it is in stock now:
Hifimediy CS4398 DAC "direct out", TCXO oscillator
they write that there was a problem with the cs4398: it was burned by electrostatic discharge and they suggest now to put some diodes between the output caps and connectors.
So, I guess that this problem happens only if caps are used. If one would use a output transformer, or a buffer with a input shunt resistor, no problem would come? Is this correct?
Any experience (good or bad) ??
Old 12th May 2013, 01:22 PM   #344
xslavic is offline xslavic  Moldova
To have 192khz,pin10 of cs4398 needs set high
Old 12th May 2013, 02:50 PM   #345
OlavHaal's Avatar
Wink Just So....
Hi there all!
Mine Direct out Dac did just that - got burned and smelled badly. First try with only caps on output. Got it fixed and mounted some Sowthers on the balanced output: and now it has been playing beatiful music for 6 months - and is so clear and distinct with no signs of smoke anymore. So that fixed my problem.
Happy listening all.
Olav
Old 13th May 2013, 01:18 PM   #346
What Sowters did you use? the 3575?
And where did you source them?
Old 13th May 2013, 05:23 PM   #347
OlavHaal's Avatar
Arrow Hi Nakamoomin....
Hi there ---
As an answer to your question I can say that I used the 3603 with 4 300ohms resistors from the balanced output. If you look back to post 250 and several posts around there - some of us did use somewhat equal configuration with the sowther transformators!
And I can send you some photos/layout for the balanced output(but there are some good descriptions around post 250 as well).
And if you are in this area (westcoast) in Norway -. you could both look and listen to my solution!
Best
Olav
Old 6th June 2013, 05:41 PM   #348
Hi there ---
Best
Olav
Hi Olav!
Old 6th June 2013, 06:03 PM   #349
Hi xslavic,
I just want to start recording and monitoring at 192kHz. I was trying now and the DAC is not behaving as it should.
How would you advise me to do?
Old 9th June 2013, 02:20 PM   #350
PJN is offline PJN  United States
I've had an issue with my DAC as well, it outputs only through capacitors. I had a problem with intermittent loss of signal on the optical input, I needed to reheat the board connections to reflow the joints which fixed the problem. But after hooking it back in my system it plays ok, but the level of detail in the music seems to be noticeably less, seems to have lost resolution in the upper frequencies. Any ideas?
PJN
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright 1999-2017 diyAudio
