| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#231 |
I received the DAC today. Upon powered up, the onboard LED failed to lit up although the 5V and 3.3V showed correct output on my multimeter.
Further measurement of the couple output (after the caps) measured a 2.5VDC at both LH and RH channel with no digital inputs. Is this normal? |
#232 |
Hi, it's normal. And I have to explain what the LEDs mean on board.
1. LED near USB input, indicates the USB active or not. 2. LED on SRC module, light up when the signal input is locked(correct). 3. LED on switch board, means there is signal active on the current channel. |
#233 |
Hi thanks for the reply. I took the step of faith last night and hooked up to my system and it works! Haha.
The sound is a little flat now, probably need to burn in. BTW, would it be better to use optical input or coaxial? |
#234 | |
#235 |
how would the sound of the CS 4398 directly describe out?
I have a 40 € the DAC is just great. He is firmly on 24bit 192 khz set. Has a great impedance converter output stage. Powerful bass and treble fine resolution Spatial resolution. http://www.elv.de/24-bit-audio-da-wandler-ada-24.html Is the DAC of HiFimediy fine? Thanks for an answer Dieter |
#236 |
#237 |
The CS4398 sounds very near to the analog and natural... The descriprtion of the hifimedy's application looks awsome. Maybe the best CS4398 DAC Board on the market... Absolutely to have and test !!! Testing by me coming soon... It is possible to find CS4398's KITs for ~20 EUR with few mod you can obtain a nice sound spending less then ~60 EUR and ~2 days work.
#238 |
CS4398 chip is a differential output dac
Your board could support differential output ? Last edited by DIGORA; 9th September 2012 at 07:57 PM. |
#239 |
#240 |
| Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 | zog666 | Digital Line Level | 48 | 2nd April 2012 02:48 PM |
| Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 07:03 AM |
| Gigawork CS4398 DAC +... | McCrackers | Swap Meet | 5 | 30th December 2010 07:30 PM |
| DAC using CS8416 and CS4398 | binspaul | Digital Source | 1 | 29th September 2009 11:37 AM |
| Zhaolu CS4398 DAC board | cotdt | Swap Meet | 3 | 11th April 2007 01:06 AM |
