| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#201 |
@ HifiMeDIY.
Got two questions? Have you ever considered Tenor 8802L as USB interface chip? E.g. Audio-GD devices show clear improvements by using (async) Tenor 8802L over (adaptive) 7702L. Are you still working on a multichannel device? If yes -- do you also consider building a multichannel USB-DAC? (That's what the DIYworld is looking for ?---- Ah and one more ( a little off topic): As you know I'm a quite happy owner of your DDX320 (...replacing my Twisted Pear Buffalo ) - no issues with DAC outputstages, cableing, connectors, amp inputstages, asf. )Would it be possible to attach the 4398 DAC input stage discussed over here to the DDX320 module?? It would also allow to drive the amp directly via USB!?!? And you might get rid of the CS8416 problem. Thx
::: Squeezebox Touch Toolbox and more ::: by soundcheck Last edited by soundcheck; 3rd August 2012 at 08:34 AM. |
#202 |
hey, when is the newest version will be available?
#203 | |
We still use TE7022L on new DAC, although we already support 192k now, I think 7022L is good enough and will acceptable price. But I can use better chips anytime when we believe we should. ![]() And I'm still working on the DDX, with slow progress as you know I will try your idea, hope it works![]() Hi, already available I think. |
#204 |
Got the new cs4398a few days ago. Really fast shipping!!!
#205 |
Why shouldn't it?
It IMO makes no sense to develop and maintain two different input stages for the very same purpose. That'll save you a lot of design and maintanance related efforts/cost once it's done. Looking forward to your feedback.
::: Squeezebox Touch Toolbox and more ::: by soundcheck |
#206 | |
why not based on CM6620 Last edited by alkasar; 14th August 2012 at 03:04 PM. |
#207 | |
I also vote for new USB chip, either one of the TE or CM as long as it supports Linux. |
#208 |
I mean the COAX and OPT inputs.
#209 |
I have some experience with high speed usb receivers : TE7022 (24/96) and TE8802 (24/192 asynchronous) much more expensive.
Frankly speaking, I could not hear any difference. I sold the 24/192 device (musiland monitor usd 01) soundcheck's comment and my +1 was to investigate a multichannel usb dac. It's a different project. |
#210 |
"Hi are you sure about using 10 kOhm in each leg of the primaries ? This is way too high. I used 1 kOhm (sounded like I used tone control) and was not satisfied and went to 470 Ohm which was an improvement.... "
I did not design the circuit I have here. I just built it on a designer supplied PCB. But you are correct about the resistors! They are 1k resistors and they work very well with the Lundahl LL-1690's. If you send me an IM I will send you a copy of the schematic but I will not post it here since it is not my design... Mark Last edited by Mark Allen; 16th August 2012 at 11:01 PM. Reason: Left out Jean Paul's Quote |
| Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 | zog666 | Digital Line Level | 48 | 2nd April 2012 02:48 PM |
| Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 07:03 AM |
| Gigawork CS4398 DAC +... | McCrackers | Swap Meet | 5 | 30th December 2010 07:30 PM |
| DAC using CS8416 and CS4398 | binspaul | Digital Source | 1 | 29th September 2009 11:37 AM |
| Zhaolu CS4398 DAC board | cotdt | Swap Meet | 3 | 11th April 2007 01:06 AM |
