Hifimediy direct out cs4398 DAC - Page 17 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st March 2012, 12:35 PM   #161
PJN is offline PJN  United States
negative goes to the ground on the RCA outs.
Old 21st March 2012, 04:37 PM   #162
poirson is offline poirson  France
Hello
I did that but it isn't working ?
What's happened ?
Old 21st March 2012, 06:21 PM   #163
Originally Posted by poirson View Post
Hello
What's happened ?
Sorry the pictures arrive.
Old 21st March 2012, 07:08 PM   #164
I tought the ground on the cs4398 and not on the rca, that's why.
So, very clear but a lot of hum in the 2441 and the 2405. A bit of compression too and distorsion.. I used intertechnik zn cap 1.5uF and russion pio 220nF in parallel.
What's the solution to reduce the noise first ? I'll see later if I keep this solution or no.
Bye
Old 22nd March 2012, 12:32 PM   #165
Try hooking the grounds from the RCA outs to the ground on the board.
Old 23rd March 2012, 02:49 AM   #166
i2k92 is offline i2k92  Indonesia
@HIFIMEDIY : any news on WM8741 test ?
Old 23rd March 2012, 06:51 AM   #167
when I hook the rca ground on the main ground I don't have sound ?
Old 23rd March 2012, 11:58 AM   #168
On my amp (carver pm 1.5) I measured the ohmic value between xlr ground and earth ground : 27kohms.
The dac works when the rca ground isn't on the earth ground of it, so on the ground of the input amp's xlr.
May be shouldn't I use the earth ground on the dac ?
Old 29th March 2012, 01:42 AM   #169
I tested the wm8740 and found that a added LPF is needed . so I think we can't use it by now.
Old 14th April 2012, 01:57 PM   #170
Default new toy
I use socket for up-sampling, so you can use the module or some jumpers.
And a MCU is used. A sample board is ready to debug
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright 1999-2017 diyAudio
