Hifimediy direct out cs4398 DAC - Page 16 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th February 2012, 01:30 PM   #151
Yes, this is the Cap that i use. 4,7 uF . It sounds different than the Copper ones. They fit my system very well, so ... I played them for one week now, they sound very well and stable, so i do think that the first " break in " period is done . Give them a try if you do not spend to much on postage for them . One thing : They are very big, theoretically not optimal in this position, but the sound is brilliant. I do not think that the sound will get " better " ( tubes are a different thing, but... ) with the BCF, but maybe youŽll do a comparison ...
Old 29th February 2012, 03:20 PM   #152
i2k92 is offline i2k92  Indonesia
Agreed & thanks for sharing.
I fully understand that there's always risk that tube won't sound any better than kondensatoren direct or transformer out but I use this opportunity as my learning process toward tubes world. In fact I never though that in my system this DAC sounds better via USB than via Coax, but that's what happen and the difference is significant.
So just expect the unexpected (as in your case where cheaper oil sounds better than more expensive copper).
BTW, I still expect that hifimediy will release other DAC chip module for this DAC. WM8741 will be very nice !!!
Old 10th March 2012, 02:03 PM   #153
I'm not sure WM8741 will work good or not on this board. So I decide to have a try...
Old 11th March 2012, 10:18 AM   #154
something with i2s inputs would be awesome for this dac board
Old 16th March 2012, 03:00 AM   #155
oon_the_kid's Avatar
Hi hifimediy,
I am looking at the picture of the DAC board and I notice there is a smaller daughter board at the side on what appears to be a volume control.
Does the DAC come with an in built volume control?
I bought the 1853 DAC from you and in the process of casing it up.
Contemplating buying this one too. How would you compare the sound of this one compared to the 1853?
Thanks.
Oon
Old 16th March 2012, 05:12 AM   #156
Originally Posted by oon_the_kid View Post
Hi hifimediy,
Thanks.
Oon
The smaller board is input selector switch. It doesn't have any vol control.
Old 16th March 2012, 10:45 AM   #157
How is the sound like compared to the 1853...
Sent from my MB860 using Tapatalk
Old 20th March 2012, 07:02 AM   #158
poirson is offline poirson  France
Hello, guys !
I'mfollowing your thread for few cause I want to upgrade my lem-dac v3.
Actually I change the aop by lme49720 but the direct output stage like me so much.
Just a question for symetric output, just put 2 caps by way (+ and-) ? that's it ?
otherwise in asymetric, the caps are on the +, and the - is useless ?
Just a very simple question.
Old 20th March 2012, 03:58 PM   #159
PJN is offline PJN  United States
Hi Poirson,
You need just one cap per channel on the + out to your RCA's from the DAC, so two caps total per dac.
PJN
Old 20th March 2012, 06:19 PM   #160
OK but I found that about the negative output of the dac.
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright ©1999-2017 diyAudio
