Hifimediy direct out cs4398 DAC - Page 15 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th February 2012, 09:38 AM   #141
Originally Posted by i2k92 View Post
What do you mean by output 2 ?
I suspect the harsh sound is due to the output caps. I was unlucky because the week after I ordered it, hifimediy ships the board with Mundorf.
Previously I have almost similar experience with hifimediy tripath amp. Either change it to better caps or wait some time until it breaks-in. I actually prefer to change it to some PIO K75 caps but I don't have any at this time.
There's a jumper on the board to disable the upsampling, but it is soldered and I don't want to make any changes before it's break-in. Let's see in about 1 week. PS: I tested it using coax input only.
You can read about BCF here : It's About Time&Ultra-Linear Line Stages
There's a link somewhere on that page about the PCB sale. The reason why I choose it because it's simple, I don't need gain and I can borrow some tubes from my friend for experiment. I'm one of those stupid people who thinks that to have a good sound we need tubes :-)
Here's the photo of the stuffs (powered by 16$ r-core trafo):
Nice case. It looks tidy and clean.
Old 20th February 2012, 10:29 AM   #142
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
What is the price for the :
"Hifimediy “direct out” DAC: cs4398, w/upsampling 192/24 cs8421, TCX0 and TE7022 USB, MUNDORF MCAP"
It says 00.00$
Regards Åke
Old 21st February 2012, 08:41 PM   #143
It says 00.00$
Hmm, thats attractive pricing i've paid $99 and it was discounted from 105 dollar. New stock is expected mid march. Maybe pricing is unknown at the moment.
Old 23rd February 2012, 10:23 PM   #144
Default Digital noise through usb connection
The dac is directly connected to a pair pf sta508 arjen helder monoblocks with a 50Kohm alps r27 volume control, but i notice a clear digital rumble through the speaker that disappears when disconnecting the usb connector. Is it normal to have that kind of noise with this board. I also have a rather loud tick when changing sample frequency. What should be checked?
Old 24th February 2012, 01:53 PM   #145
i2k92 is offline i2k92  Indonesia
I have both coax & USB connected to PC and no audible noise at all. Connection : DAC USB onboard connector > USB cable > Neutrik USB chassis connector > another USB cable > PC.
And perhaps I'm going mad, but USB sounds better to me than coax (the USB port is shared with a wifi dongle)
Hifimediy : where do the USB port on the DAC get the power ? from PC or from DAC internal PSU ?
Old 24th February 2012, 03:19 PM   #146
I agree with you that USB sound better than coax or optical. Tried both, but coax/optical sound dull lifeless compared to USB. What is done to shield unwanted signals from the computer on this dac?
Old 24th February 2012, 04:28 PM   #147
Nothing other than put it on separate metal chassis. To clean up AC, I install schaffner IEC filter.
Old 26th February 2012, 07:21 AM   #148
Hello everybody,
I'm new here. I have a newbie question:
do you think possible a direct connection of the cs4398 balanced output with the balanced input of "the wire" bal-bal version without using any caps?
Will the 4398 offsets on + and - output zeroing at headphone out?
Old 29th February 2012, 12:00 PM   #149
i do have the same probs when using the usb on my netbook. when i unplug the netbook´s powersupply the noise is gone. no chance to get rid of it by using an ic filter. any suggestions on that ? the coax is clean and very good sounding with my hiface spdif ....
i changed the copper obbligato caps to the film oil obbligatos, no bypass added - HIGHLY recommended !!!
Old 29th February 2012, 02:14 PM   #150
It's strange, I don't have that problem at all. My PC uses Pico PSU module with external 60watt DC brick.
Do you use Obbligato oil cap like this : eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
and it sounds better than the copper + vishay bypass ? what value do you use ?
Mine's still attached to the Epcos, still waiting for component for BCF tube buffer. It's so sibilance with lot of "ssssshhhh", perhaps just a matter of break-in as based on my past experience Epcos & Wima takes ages to properly settle.
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 03:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 08:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 12:37 PM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 02:06 AM
Copyright ©1999-2017 diyAudio
