Hifimediy direct out cs4398 DAC - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 8th December 2011, 08:41 PM   #111
palmito is offline palmito  United States
palmito's Avatar
Default Newbie questions
Please pardon my ignorance. I've been reading to see which cheap DAC to get and this one seems the most promising for me so far. My plans would be to use a lampizator kit for ouput. My questions are: 1) I should be able to use the lampizator kit with this dac? 2) If I order it without the USB interface, can I later add a USB to I2S card that does higher sampling rates (192khz for example)? Something like the ExaDevices exaU2I when cheaper ones appear on the market... Thanks
Old 9th December 2011, 09:24 PM   #112
Default Why adding up-sampling ship?
Hello,
I don't understand this specific point: CS4398 has up-sampling capabilities. So, what is the point in adding an up-sampling chip?
Thanks for any comment on that point!
Old 10th December 2011, 05:03 AM   #113
Hi, I think this DAC is easy to work with many amplifier kits. And you can use a USB to cox/optical module to work with the dac. We don't have I2S input on board.
Originally Posted by Ribet View Post
Hello,
Hello, I don't know cs4398 has up-sampling. I know it has sample rate setting pins and we already set it to accept 100~200kHz, and we up-sample the input signal to 192kHz default. The up-sampling function make the DAC chip work always at same sample rate regardless the input SR.
Old 10th December 2011, 09:05 AM   #114
Do you mean 44.1kHz source is up-sampled to 192kHz?
Old 10th December 2011, 11:49 AM   #115
yes. If the signal on s/pdif input bus is 44.1k or other sample rate, the I2S signal's sample rate on the output of receiver chip will be same, but after cs8421, the sample rate will become 192kHz.
Old 10th December 2011, 02:26 PM   #116
cOz is offline cOz  United States
It would be really cool to see someone deatil how to Lamphizator one of these kits.
Old 13th December 2011, 03:27 AM   #117
oon_the_kid's Avatar
I am curious about the DAC, mainly some technical specs. I am trying to put it to a class A amp without any capacitor.
Trying to find out these parameters.
1) what is the Vout peak to peak?
2) What is the DC voltage at the output?
Thanking in advance.
Oon
Old 26th December 2011, 09:21 AM   #118
Oon
Hi, Vout(pp) is about 3.4V, and 2.5V offset.
Old 27th December 2011, 01:51 AM   #119
Thanks,
Oon
from my MB860 using Tapatalk
Old 5th January 2012, 07:32 PM   #120
Hi.
I want to replace the digital board of a Kora Hermes II dac (which uses a cs43122 dac chip) with a newer dac board, and I am considering this board. I want to retain the analog stage which is a ECC82 tube output stage, which I like very much, and gain some channel separation, which is basically the only complaint I have with the Kora hermes II dac, and maybe some detail. I have 2 questions:
1) does this DAC board accept 24/192 data from the coaxial input?
2) Is it practically difficult in this board to take the differential inputs directly, place a capacitor on each one (so four capacitors rather than two) and send those to the tube stage? I have a decent knowledge of theoretical electronics (I am a physicist) but my soldering skills are rather basic...
thanks,
Massimiliano
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright 1999-2017 diyAudio
