Hifimediy direct out cs4398 DAC
Old 12th November 2012, 09:34 PM   #301
Nyky is offline Nyky  Italy
Default IMAGE LAMPIZZATOR BY NYKY
I attach photo of My LAMPIZZATOR used for the DAC, they are also there the schemi,guadagnos(GAIN) very low 1:1 even if he/she forces to hold the volume to -8db in entry (Foobar) otherwise Saturated entry, Sound ECCEZZIONALE,TRASPARENTE, from FARE,valvole to be used 6135 GE 5 stars (BEST),o 6c4 GE, for information make to know me hi
Old 17th November 2012, 08:35 AM   #302
jovien is offline jovien  France
I working on a project which include this Direct Out DAC (can't wait to buy it !) And I would like to know if we can directly connect an I2S input ? It seems that the question has been already asked, but I haven't find any clear answer in this thread. And Google won't help me on this task
In my case it would be to connect a Raspberry Pi (I2S output via GPIO pins and some hardware). So, is it possible ?
Old 17th November 2012, 06:44 PM   #303
Ciao,il my DAC strongly evolves him with a form of condesatori MKP+ Elettrlitici for disaccoppiare the Analogical Digital part and to lower the impedance of the battery, the sound times is very More transparent low very articulated bello,Si can also use with transformer feeding. For your curiosity the Battery after 12H Plays anchors!!! V5 OK,V3,3 OK
Old 22nd November 2012, 11:58 AM   #304
hifimediy is offline hifimediy  China
Hi, yes you can try the I2S to M1 connector. And signals show below. Remenber to remove the upsampling module or jumpers on M1, and keep I2S cable as short as you can. And do not plug it when poweron. The I2S signal will directly go to CS4398.
BTW, keep JP2 open to select PCM mode.
Old 29th November 2012, 08:02 PM   #305
sex is offline sex  Indonesia
Banned
Hi ! !
This is my first - and certainly not last - post at diyaudio.com.
I currently have this CS4398 DAC... Finished CS4398 + CS8416 USB DAC With Transformer+case | eBay
I'd like to replace the PCB with the Hifimediy 'direct out' version.
Is this an easy switch, any advice or help please?
Thank you kindly in advance.
Lykt
Old 2nd December 2012, 04:34 PM   #306
Default Ended!!
Hi, verdict: AsusD2x (digital coax) + Dac to battery +6135 (6C4) sound, exceptionally middle vinyl! Amazing range, voices very real natural, low laodness no!
Old 6th December 2012, 09:47 PM   #307
Default TRANGE!!!
Hello, I tried the usb input, and it sounds MUCH better than the COAX.però someone can explain because it accepts file to 192kHz! (Flac 24 bit 192kHz HDTRACS) thanks
Old 7th December 2012, 11:18 AM   #308
Default Problem!
probblema not rieso more 'to be recognized by the igresso COAX to the dac, I tried everything, drivers, asio 2.0 miscellaneous settings nothing! Idriver USB and as if they had taken control, if anyone can help me thanks!
Old 7th December 2012, 06:24 PM   #309
Default Problem Windows 7 32
Hello, the problem is not the DAC as both ligresso COAX that OTICAL with ua source other than the PC (DVD Player) go! Aggacio The indicator lights, windows nomination "SPDIF Interface (USB)" then it conflicts with the VERA SPDIF of ASUS d2x.
Old 12th December 2012, 12:20 PM   #310
Great ! Thanks.
Last question, can you tell us what value is the potentiometer's diameter of the source selector ? 6mm or maybe more ? (6mm would be perfect for me )
Board shipped, can't wait for it to be home ! When everything will be build, I will post my thoughts and the detailled ressources I've needed. For now, my project (DAC only, Raspberry may come after, don't know yet) costs 208,47€ everything included (the other parts will be bought from Audiophonics.fr, they can ship to the international).
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 03:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 08:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 12:37 PM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 02:06 AM
Copyright ©1999-2017 diyAudio
