Hifimediy direct out cs4398 DAC
Old 10th September 2012, 06:21 PM   #241
puredyne is offline puredyne  Austria
This is a general purpose isolator for balanced/unbalanced conversion... Hopefully the signal is coming out high enough for a direct amp connection... I've payed 122.16 Pounds for two OCC wired Transformes.
Datasheet: Sowter Type 3603
OCC Option: SOWTER TRANSFORMERS OCC OXYGEN FREE WIRE
Old 11th September 2012, 07:15 AM   #242
fandersen is offline fandersen  Canada
Originally Posted by Ahlek View Post
Is there a specific model of transformer that is highly recommended at reasonable price?
I used a set of Jensen JT-11-DMCF transformers. Not the cheapest but they work really well with CS4398. The Experience with this DIY DAC thread has a lot of discussion of various transformers from cheap to expensive for a CS4398 based DAC.
Flemming
Old 11th September 2012, 12:35 PM   #243
Ahlek is offline Ahlek
Thank you very much for the link. So far I like the sound of the DAC very much and hope to maximize its performance.
Old 12th September 2012, 03:11 AM   #244
MurphyUHF10 is offline MurphyUHF10  Australia
MurphyUHF10's Avatar
Hi There,
I ordered mine a couple of days ago and am greatly looking forward to this DAC!!
I have read this entire thread from start to finish, and am now up to date
Ta
CM
Old 18th September 2012, 11:18 AM   #245
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Thumbs up My Dac arrived.....
Hi all!
Today my sweet little NewDac came in the post - thanks to HiFiDIY for perfect boards - and I look forward to listen to Hi-Res files on this Less-is-More kind of doing digital sound. Just now I am listening to Christe Winn on 24/96 Wav files on my old DacMagic(with OpAmps and filters). My B1-Pre has only 2 transistors and my SITLamp has ONLY 1 transistor(Sony 2SK82). Think it will be even more musical with this sc4398dac(hope so).
But first I have to go 14 days offshore to my telecom-schedule. Have to wait till beginning of october for to get it singing.
Best to all
Old 18th September 2012, 04:19 PM   #246
nakamoomin is offline nakamoomin  Norway
Got mine today too.
Busy comparing the tiny HifiMeDiy USB DAC to the ODAC at the moment. Will report back here once I get the Direct-out DAC up and running.
Old 18th September 2012, 04:54 PM   #247
I've tested for a few hours... State Of Art Sound, streamed from my HDSP@LinuxBOX! ...This DAC is real love, thanks a lot!!!
Old 18th September 2012, 05:21 PM   #248
OlavHaal's Avatar
Default Hi Puredyne...
Thanks for your report - I wonder if you have tried the DAC with oversampling, since as your photo shows you are running Non-Oversampling for the moment. And if you could say what you prefer of the 2 possibilities?
Best
Olav
Old 18th September 2012, 05:32 PM   #249
Hi OlavHaal, Via Jack Server the hardware upsampling is totally unnecessary, all system streams are eventually summed and resampled by the server.
Old 2nd October 2012, 08:46 AM   #250
I have the same transformer (from HiFiMediy?)..
What rating mains fuse have you chosen??
Ta
CM
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 03:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 08:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 12:37 PM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 02:06 AM
Copyright ©1999-2017 diyAudio
