Hifimediy direct out cs4398 DAC
Old 28th August 2012, 08:53 AM   #221
soundcheck is offline soundcheck  Germany
Originally Posted by dahlberg View Post
You have said that there is no I2S connection on this dac but schouldn't that
be possible if the SCR is removed ?
They probably masterclock the receiver/ASRC and DAC synchronously. (That's the case on the DDX320 at least)
I proposed already to HifiMe to think about I2S-in only devices (DAC and DDX), since many potential customers are running USB2I2S interfaces.
For them these devices would be much easier to built at even lower cost on both sides.
The question is if the sound quality will be the same.
Cheers
Old 29th August 2012, 08:29 PM   #222
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Cool Hi to all!!
As a fairly new member of the dac-building guerilja, I have just bought the sc4398dac from your site - Hifimediy. As an earlier builder of the Pass-B1 Buffer and the SITamp(L`Amp-resistor based) I think I can get it up and running - or else maybe someone here can support some suggestion....
It will not arrive until the 20 of september - so I can get a good enclosure and find where and if I can move the D1-led to the faceplate or things like that...
will be nice to hear if this Dac can beat my old DacMagic(somewhat tired of that WM8740 and my Squeezbox Touch uses 8741)
Looking forward to hear a new fresh take on the digital line...
Best to all
Olav
Old 29th August 2012, 09:03 PM   #223
audiolic is offline audiolic  Canada
let us know
Old 1st September 2012, 03:38 AM   #224
Ahlek is offline Ahlek
Originally Posted by analog3000 View Post
The Obbligato alone sounds very " High End ". Lots of details and airy 3 D Soundstage. The Bass is ok. With the 1837 everything becomes more " Ground ". Warmer sounding but less detail and 3D ( as always ;-) . I like it more, itīs more musical to my ears. I will listen to it a few days, maybe Iīm going to step up the level of my Tweeters in the end a bit, but thatīs ok ...
I ordered a pair of the cheaper Obbligatos ( film oil ) to see what they will do. itīs fun to fiddle around with a solution that always sounds good in the end ;-) .
AND : Should i go the Lundahl ( 1517 ) or the Aikido Way ? Hmmmm ....
What's the Vishay 1837 cap value you have used? When you mentioned bypass, do you connecting in parallel with the Oblbligatos cap?
Old 3rd September 2012, 05:35 PM   #225
puredyne is offline puredyne  Austria
Hi all,
I don't know much about eletronics. I'm simply a Synth DIY builder and user for ~3 years now, and a Linux Audio User since 2002. I am using as a Jack Card a RME HDSP9632 and a Card Zoo of other Alsa Devices to plug & sync to the Jack Audio Server a couple of Beis AD24QS via Alsa_In, for monitoring and pre-mix / virtual summing applications. I'm very enthusiastic about the State of Art Sound from Linux Audio in conjunction with the Cirrus Logic Flagship A/D - D/A Converters. A Alsa_In example: http://demosynth.dyndns.org/files/beis/JackServer.png ...The beauty of Linux RT or Low Latency & Jack Audio Server is the removal of the Jitter caused by the OS.
Soon I would buy & try this nice board!
This past weekend I've sold my fantastic Beis DA24QS to help financing this project.
Therefor I am thinking of trying this DAC board, first without the Output Transformers. Yet I do not understand whether the 1K min. load is needed also through the Caps Out?
In case I do try the Sowter 3603, could someone please explain to me a wiring example for the Secondary to the >1Kohm>RCA? ...is this tansformer suited for XLR Balanced Connections? (Pins 4, 5, 6, 2) http://www.sowter.co.uk/conpics.htg/3603.gif
I've obtained these answers from Sowter and Lundahl companies:
According to the data sheet this is a voltage out DAC. The output impedance is ~120 ohms and it should be loaded with not less than 1k. The level is ~7V p-p max.
Our type 3603 would be very suitable for this. You will need to use a ~1k resistor across the secondary to ensure the DAC sees the correct load.
However, LL1690 is an input transformer with a certain copper resistance. For your type of application I would normally recommend the LL1527 or LL1527XL. These transformers performs very well with most DAC boards and chips.
Old 5th September 2012, 12:21 PM   #226
Really, nobody can explain to me how to try wiring the pins 4, 5, 6, 2 of the Sowter 3603 output transformers?
I need to know another very important thing, in order for me to expand the monitoring ADC Inputs on my System... Could it work simultaneously on this Board the Toslink or Coax Input and the USB Out?
In this case, which way is possible for me to make the internal connection with the ADC/ Coax Optical or both?
If it worked, I'd be very happy to be able to connect two more analog inputs... The internal Coax connection was perfect to maintain the a external Toslink Out from the ADC... If this USB Alsa Device is recognized with another Device-Name (arecord -l) than the miniStreamer, two times as happy for 2x more analog inputs possibility, seeing that it is impossible to use more then once same chipset or device (alsa device number ordering configuration for the usability: /etc/modprobe.d/alsa-base.conf).
Old 5th September 2012, 02:26 PM   #227
hifimediy is offline hifimediy  China
Hi, may be you can try this connections.
Old 5th September 2012, 02:30 PM   #228
And the USB part has SPDIF input on board, default connected to the TX(pin21)of WM8805, through R6 on the bottom side, that means you can use the record function when playing. May be you can do some solder work to make it works as you mentioned.
Old 5th September 2012, 03:11 PM   #229
Thank you hifimediy,
I will place the order as soon as possible and look forward to try your creation.
Old 6th September 2012, 01:34 AM   #230
Hi, puredyne. I saw the green wire in your picture, and it's ok if you use the input1~2, the signal will come out from DAC and USB to PC at same time.
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
