Hifimediy direct out cs4398 DAC
Old 19th August 2012, 09:40 AM   #211
Ahlek is offline Ahlek
Hi I'm quite new to this forum. After reading a few pages of this thread, I went and ordered the DAC.
Question: will I have issue sending the output of this DAC directly into my Rotel integrated amp (RA-02) which I use as per-amp only.
Old 21st August 2012, 10:04 AM   #212
hifimediy is offline hifimediy  China
Hi, whether a DAC can work with a amp, that depend on the output level of the DAC, and the gain of the amp. Also, make sure the input impedance of amp is no less than the minimum resistance of DAC. The DA-X0 output up to about 3.4Vpp on coupled output or 6.8Vpp on balanced output. And CS4398 itself drives 1kohm min load.
Old 21st August 2012, 10:16 AM   #213
Hi thanks for replying. This is a commercial amps. I can just measure the input impedance by putting a multimeter across the inputs?
Old 21st August 2012, 10:36 AM   #214
alkasar is offline alkasar  France
no this won't work
read this will give the answer ROTEL RA-02
Old 21st August 2012, 10:45 AM   #215
Yes. But I think most of amps has higher input impedance that can be used. Class-T amps is 20kohm and some class-AB chip amps even higher (up to 100kohm).
Old 21st August 2012, 11:02 AM   #216
Originally Posted by alkasar View Post
no this won't work
Hey thanks! This is great!
Old 21st August 2012, 11:05 AM   #217
It looks like RA-02 has input impedance of 47kOhm which should be OK for the DAC?
Old 21st August 2012, 11:58 AM   #218
Old 25th August 2012, 02:23 AM   #219
Default DSD mode settings
Hi, we use the small switch board to set DSD over-sampled rate. State list bellow.
Old 28th August 2012, 08:38 AM   #220
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
You have said that there is no I2S connection on this dac but schouldn't that
be possible if the SCR is removed ?
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright ©1999-2017 diyAudio
