Hifimediy direct out cs4398 DAC
Old 12th May 2012, 01:54 PM   #181
hifimediy is offline hifimediy  China
Originally Posted by tubo View Post
please help! my dac will not power up and the dac heats up very hot....the led that indicates lock does not light up.....im still getting 5 volts from the regulator. i bypassed all the electrolytics on the main board and was still playing music then i put in a tube output stage then suddenly the dac will not light up...
please help.....thnks
Hi, tubo.
"dac heats up very hot", Please check both the analog and digital power supply(5V and 3.3V). Test point shows below:
Old 14th May 2012, 05:17 AM   #182
tubo is offline tubo  Philippines
Originally Posted by hifimediy View Post
Hi, tubo.
Hi nick, the reading on the test. Points are exactly. 3.3v and. 5volt. What should i do next?Tnx
Old 14th May 2012, 11:58 AM   #183
Hi tubo.
If the analog power regulator(U11) also output normal voltage (5V), I think it must be the DAC chip itself been damaged.
Yubing
Old 14th May 2012, 02:22 PM   #184
tnx, yubing. i ordered a replacement dac board.
Old 15th May 2012, 12:24 PM   #185
For direct output mode, use a resistor series in the output will sometimes protect the chip.
Old 24th May 2012, 11:11 PM   #186
jovien is offline jovien  France
I'm new here, it's been 3 days I'm searching for "the" DAC I'm looking for. I may be restless but it's been 9 days without any news
Any idea when the next batch will be for sale ? And any feedback of the previous ones ?
Thanks for all,
Jovien C.
Old 30th May 2012, 03:06 AM   #187
ozcal is offline ozcal  Australia
What value of resistor is required ?
Old 23rd June 2012, 08:22 PM   #188
audiolic is offline audiolic  Canada
for a 3way setup would it be useful to have a way to link between the clock of multiple Cirrus dac like yours??
Old 23rd June 2012, 08:26 PM   #189
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Adding unnecessary components with high voltages in DACs (that have 2 V outputs) involves some risks... Better keep it passive with output transformers. Way less risk. CS4398 likes transformers a lot.
It's only audio. Member of the non modular PCB design committee
Old 25th June 2012, 07:49 PM   #190
would you be interested in making a 3 spdif input dac + 3 best jitter remover reclocker + 3 CS4398 dac chip but one clock and one very good power source. I don't know how much one could save versus 3 of your CS4398 dacs
it's for crossover utility after the new nanoDIGI 2x8K | miniDSP
does not output adat so i'm stuck and cannot use my emu1820m but at the same time i find the cost of 3 hifimediy to be a little to much... also i wonder how 3 different clock and power would affect the sound once merged in the 3way 3amped speakers..
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright ©1999-2017 diyAudio
