Hifimediy direct out cs4398 DAC
Old 13th February 2012, 05:59 AM   #131
analog3000 is offline analog3000  Germany
Hey,
this thread is going to get some life again, fine.
I tried different things, i also connect the output 2 directly to my amps. Impressive.
@PJN : You use four Sonicaps to couple, direct on the Output 2 or instead of the 4 Caps on the board ?
@ i2k92 : Aikido BCF, maybe a good idea ? Where do you buy the board ? Have you ever tried it without the upsampling activated ? Maybe this is the " harsh " sound that irritates you ....
I personally donīt like upsampling all the time, i do think that it sounds undynamic and unrealistic in most of the times. Although it may sound impressive .....
Old 13th February 2012, 07:54 AM   #132
i2k92 is offline i2k92  Indonesia
Originally Posted by analog3000 View Post
Hey,
What do you mean by output 2 ?
I suspect the harsh sound is due to the output caps. I was unlucky because the week after I ordered it, hifimediy ships the board with Mundorf.
Previously I have almost similar experience with hifimediy tripath amp. Either change it to better caps or wait some time until it breaks-in. I actually prefer to change it to some PIO K75 caps but I don't have any at this time.
There's a jumper on the board to disable the upsampling, but it is soldered and I don't want to make any changes before it's break-in. Let's see in about 1 week. PS: I tested it using coax input only.
You can read about BCF here : It's About Time&Ultra-Linear Line Stages
There's a link somewhere on that page about the PCB sale. The reason why I choose it because it's simple, I don't need gain and I can borrow some tubes from my friend for experiment. I'm one of those stupid people who thinks that to have a good sound we need tubes :-)
Here's the photo of the stuffs (powered by 16$ r-core trafo):
Old 13th February 2012, 02:52 PM   #133
--> there is someting on the board, in front of the 4398, named " output2 " ;-) .
--> yes, mine is without the mundorfs too .
--> maybe iīll go with obbligatos ...
--> thanks for the link !
Old 13th February 2012, 04:05 PM   #134
PJN is offline PJN  United States
analog3000,
I just bypassed the existing flim caps that were on the board, very easily done as there are provisions for it already on the board. You only need two caps, one for each channel.
PJN
Old 13th February 2012, 04:08 PM   #135
PJN,
provisions on the board ? iīll have a look ... Two Caps ? Can you post a Picture, please ?
Thanks,
Michael
Old 13th February 2012, 05:22 PM   #136
Ouch. Finally i found it. Thanks.
Old 13th February 2012, 08:38 PM   #137
... and bypassed the standard caps + added two Obbligatos ( CopperCaps ). NICE ! They add a fine compression. Not to much, but very nice. Good Soundstage and Dynamics. not so Dynamic as a good Transformer, but very NICE ! Maybe iīll go the Tube Way too ....
Michael
Old 13th February 2012, 10:39 PM   #138
... finally bypassed the obbligatos with vishay 1837. Boing. Thatīs it. No coloration, natural stage and transients. Good overall dynamic. Hope it is still sooo good next morning.
N8,
Michael
Old 15th February 2012, 12:15 AM   #139
Yeah I read somewhere that Obbligato + 1837 is killer combo. I've been wanting for those Obbligatos for some time now. Too bad the seller only uses expensive Fedex/UPS for shipping. That will cause the custom tax too high to justify the purchase.
Old 15th February 2012, 11:40 AM   #140
The Obbligato alone sounds very " High End ". Lots of details and airy 3 D Soundstage. The Bass is ok. With the 1837 everything becomes more " Ground ". Warmer sounding but less detail and 3D ( as always ;-) . I like it more, itīs more musical to my ears. I will listen to it a few days, maybe Iīm going to step up the level of my Tweeters in the end a bit, but thatīs ok ...
I ordered a pair of the cheaper Obbligatos ( film oil ) to see what they will do. itīs fun to fiddle around with a solution that always sounds good in the end ;-) .
AND : Should i go the Lundahl ( 1517 ) or the Aikido Way ? Hmmmm ....
Hifimediy direct out cs4398 DACHide this!Advertise here!
Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 zog666 Digital Line Level 48 2nd April 2012 02:48 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Gigawork CS4398 DAC +... McCrackers Swap Meet 5 30th December 2010 07:30 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 11:37 AM
Zhaolu CS4398 DAC board cotdt Swap Meet 3 11th April 2007 01:06 AM
Copyright ©1999-2017 diyAudio
