| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
hi, a new one again. just wonder if any one done an i/v stage for this dac board: DAC AD1865, NOS 2.0 Balanced output?
there is very short thread feb2011, but not mush for me! i put a pair of Sowter9545 with secondaries in series. without any i/v resistor it gives 1:10 ratio. when playing a -20db pink-noise i get 1.6v. did many tries whit different i/v resistor but the output decreased dramatically!problems; 1- it's too low for me. my PSAudio DL3 gives 2.8v out! 2- the sound is not so satisfyingly either! 3- no interests in tubs. found a JFET concept that seems good but difficult to place it after trannys! the resistors here and there are just killing! 4- any help? now through the beauty out of the window! almost! |
#2 |
use good resistor like I/V (200ohm) and an active output stage like my schematic
Hi-Resolution System 192KHz 24bit with EMU 0404 USB see hybrid design |
#3 |
Raindrop hui's IV stages are not too bad, he sells HDAM, FET, and Two tube versions.
I'm sure any of them would be very acceptable for use with this kit. Why not just ask him which works best and buy one of these? Perhaps you should not rule out the tube output stages, as I have recently tried a tube output stage, and found that it is clearer, gives better front to back depth, less grain and sibilance than any op-amp output stage I have tried before. Depending upon the value of the cathode resistor bypass capacitor, you can get a sound that is "tubey" or sound that is crisp and clear, and you would never recognize that it is a tube, just clean sound. (my preference) I have not tried a class A mosfet output stage, so perhaps these are also as good? Last edited by erin; 3rd July 2011 at 01:14 AM. |
#4 | |||
Previously: Kuei Yang Wang
NDFG. The transformers seem unsuited. Sound sbad. The whole DAC sounded unoffensive, but zero dynamics, zero engagement, tiny soundstage. Second, if you get 1.6V with -20dB pink noise, this is EXTREMELY HIGH LEVEL, eight times as much as would normal. I would also expect the frequency response is not flat and the sound will be very distorted. Quote:
It may be better to leave the input load off and load the secondary with 10KOhm. It gives 2.8V with -20dB noise? Quote:
I would suggest to convert from balanced to parallel DAC's (this improves SNR by 3dB, instead of making it 3dB worse, as balanced does) and using a simple output stage, using either tubes or J-Fets as gainstage, unless you can get a good quality transformers. Even then you will need I/V resistors. I think you need to think this through a little more overall. Ciao T |
#5 | ||||
thanks so much Thorsten and others for the posts. i had given up the hope to get any answer from people.
tubs seemes very complex to me! high voltage aso! maybe in a near future! i put together a simpler version of an i/v stage called JFET_Cdout with the 10k resistor it gives the famous 1.6 volt again!!! reducing the resistor hopefully gives more output. correct? and finally, what your suggestion for the best sounding solution in this case? best regards |
| Dual AD1865 balanced out DAC | boudy | Digital Line Level | 5 | 3rd February 2011 03:30 PM |
| CS8412 + filterless Non-OS dual AD1865 | cathode_leak | Digital Source | 71 | 1st March 2005 12:07 AM |
| AD1865 where? | avian | Digital Source | 2 | 5th January 2004 07:17 AM |
| Page generated in 0.11664 seconds (79.59% PHP - 20.41% MySQL) with 11 queries |
