Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th June 2011, 02:37 PM   #11
Oon,
We are discussing resitance loads, not voltage. The + and - outputs should have the same resistance across them to ground.
Old 30th June 2011, 10:54 AM   #12
oon_the_kid's Avatar
The chip is a single supply 5v, so the voltage at the output should be loaded to 2.5V, vref. Since the ideal load is 0ohm or input of an IV converter, I think it would be to just short it to vref..
Sent from my Milestone using Tapatalk
Old 30th June 2011, 11:58 AM   #13
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Okay, so you worked it out. When you asked "what is loading" I decided I had started something I was unwilling to finish.
Some comments, if you are going to use Op-Amp I/V anyway, use the OPA1632. It has many great advantages in such an application, like balanced inputs and outputs, so it makes a balanced I/V converter, very low noise, folded cascode singe gain stage architecture and very good output buffers. So you end up with a system having two equal but opposite polarity outputs so you can easily take a single ended output.
Otherwise, remember that an Op-Amp I/V circuits input only looks like a short at DC and very low frequencies...
If you where (for arguments sake) using tubes or maybe discrete J-Fets and wanted to avoid the balanced to se conversion, then loading both DAC outputs with identical I/V conversion RC (or whatever) combinations and using the signal from only one would be the choice, however.
I hope the above helps make your choice.
Ciao T
Old 4th July 2011, 12:34 AM   #14
Hey thanks for all the clarification and tips. Really appreciate it. Very likely, I will do nelson pass D1 IV stage.
But the tip on the opamp is really useful.
Oon
Old 4th July 2011, 02:09 AM   #15
If you use this single ended, it is important to remember that it's input impedance is not zero.
Ciao T
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 4 8th June 2009 02:18 AM
Differential output Keruskerfuerst Analogue Source 3 18th July 2007 12:25 AM
Using differential amps for output I/V? ezkcdude Digital Source 3 27th April 2006 08:43 PM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 04:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
