Go Back   Home > Forums > Source & Line > Digital Line Level
Old 14th June 2011, 01:57 PM   #1
Default usb to coax
I scored a ezdac(async) but its got coax in only. All my music is on my pc. My main pc is optical out, and my notebook doesnt have a digital out. All my past dacs have been usb only.
So what could i use to convert usb to coax? Can i just use any ebay $20 special or do i need something good?
NG COAX USB to SPDIF (Coaxial) Audio Converter | eBay
NEW USB to SPDIF & OPTICAL HI-FI Adapter | eBay
Old 14th June 2011, 02:28 PM   #2
SY's Avatar
The first one will give you only 16/44.1. The second will do somewhat better. For about ten bucks more, you can get a USB to spdif converter that will give you 24/96. That will cover most of the available software, but if you have any 24/192 files, you'll have to spend more. The Ebay cheapies work as well as anything else for the application. Pano and I have checked out several of these and only found one poor performer so far.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th June 2011, 03:33 PM   #3
Not having much luck finding the 24/96 versions, Ya got a link? All i find is the maudio fast track pros for $50.
Old 14th June 2011, 03:55 PM   #4
SY's Avatar
This is the one I'm using (price has gone up a bit since I bought it, but still pretty cheap):
USB Port Mini Converter SPDIF Coaxial Output DAC | eBay
They're sparse with the specs, but I routinely use it for 24/96.
Old 15th June 2011, 04:20 AM   #5
wwenze is offline wwenze  Singapore
Quite sure the PCM2906 it uses can't do 24/96.
Try outputting using KS to confirm.
Or, for Windows Vista and 7, check this screen for the available choices.
Old 15th June 2011, 05:53 AM   #6
You're right wwenze, native PCM2906/2904 does perform max 48KHz/16bits :
http://focus.ti.com/lit/ds/symlink/pcm2906.pdf
Old 15th June 2011, 06:33 AM   #7
zog666 is offline zog666  Australia
miniSTREAMER from miniDSP supports 24/96 coax in and out..
I have one but I haven't used it beyond 16/48 myself yet though.
miniSTREAMER | miniDSP
94a032849b1f446e3a1ed06cf4867a56
Old 15th June 2011, 09:56 AM   #8
SY's Avatar
Aggggh, you're right, it was the Echo box I used for that. Shows you how much 96k software I have...
Old 15th June 2011, 10:14 AM   #9
I wonder how one of these ebay thingos would compare against a standard / typical spdif output on a pc motherboard...?
Cheers
george a
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 08:47 PM
How to isolate USB instrument from interference conducted by the USB cable sunkai Parts 0 13th January 2010 03:01 PM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
Computer coax digital spdif output.. USB?... Sampling rate?? dqswim Digital Source 13 12th November 2005 03:40 PM
Page generated in 0.08817 seconds (84.38% PHP - 15.62% MySQL) with 11 queries
