Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th June 2011, 12:53 PM   #1
oon_the_kid's Avatar
Default Looking for single ended DAC with current output.
I am looking for single ended DAC with currrent out. Looking for
Sent from my Milestone using Tapatalk
Old 10th June 2011, 12:59 PM   #2
Sorry, was cut off unexpectedly. Planning on using the DAC for a power DAC project. Possibly using a gainclone chip as IV converter. Looking at a 24 bit one, since I am planning on using volume control at the source after 24bit upsampling. would like an already built up module (sorry I am a spoilt brat), too lazy fully build one.
Thanks in advance...
Oon
Old 10th June 2011, 11:55 PM   #3
Hello Oon,
I have a Twisted Pear Audio "COD" - Current Output DAC for sale. Its fully built and tested. For specifications please look here at The COD - Current Ouput DAC.
The sale thread link is
FS: Twisted Pear Audio - COD & Legato V1.0, ezDAC
Let me know if you are interested. I live in the US.
Subbu
Old 11th June 2011, 01:01 AM   #4
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
i think you will have to be very very careful, low level current output will be very susceptible to radiated interference from the high voltage, high current signal lines and transformers. fair enough building into the same chassis, but i think there will be compromises having the power amp itself be the IV convertor.
to have the current output short enough will mean the dac board and its power supplies will have to be very close to the amp. plus as far as single ended, you really dont have many choices that arent 20 year old NOS with pitifully low current output.
Imo you would be better off if you must go this way, to use a balanced dac, but use a driver chip like lme49830 that has balanced inputs and single ended outputs, then most of the noise that is picked up will be canceled out with cmmr
Old 13th June 2011, 02:28 AM   #5
Thanks for the advice. Yup I encountered the high noise isssue before when I used the inverting input of the Tripath as a I/V stage. There seems to be present day DACs single output 24 bit without going sigma delta, not sure how good it is.
Thanks on the tip, I could consider LME 49830. How would you implement it on a differential input? Do you just use it as a normal differential amp and use another chip for I/V conversion?
Oon
Oon
Single Ended Output Transformer mensur Tubes / Valves 0 5th April 2011 11:51 PM
What is the tradeoff to run a DAC single ended? DougL Digital Line Level 13 11th October 2010 06:51 PM
How do I connect a current output DAC to I/V stage single ended Thermosphere Digital Line Level 10 25th September 2010 07:41 AM
How does the current source work in a single-ended amp ? tessier Pass Labs 1 4th September 2010 08:39 AM
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 02:05 AM
Page generated in 0.09580 seconds (72.80% PHP - 27.20% MySQL) with 10 queries
