Are there also drivers for USB DACs?
Old 9th June 2011, 05:41 PM   #1
JZatopa is offline JZatopa  United States
Default Are there also drivers for USB DACs?
I'm curious if there are also drivers for USB DACs? Is anyone already using AISO drivers already? If so how low is your latency?
Old 9th June 2011, 06:02 PM   #2
kevinkr's Avatar
I've used the M-Audio Transit USB dac with ASIO and it has proprietary drivers - in fact it will not work without them. (Since the actual end device firmware was loaded after it enumerated) I don't remember the amount of latency, but I was running it with a pretty low powered laptop, and it was significant.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th June 2011, 08:26 PM   #3
Boy, between iPhone spellcheck and my sloppy typing it's hard to tell what I am talking about. I am curious about ASIO drivers for USB DACs (ie. Gigawork USB dac).
Old 9th June 2011, 08:38 PM   #4
kevinkr's Avatar
Try to look for a USB dac that has native ASIO support at the driver level. You can also sometimes use ASIO4ALL to provide most of the functionality of ASIO, but at some point it has to be converted to a protocol the particular dac and/or OS kernel supports.
This may be much less of an issue with newer versions of Windows and with Linux.. (ASIO IIRC was a work around for various windows xp kernel issues where latency and unwanted sample rate conversion, the kmixer, etc.. were issues.)
Old 9th June 2011, 10:27 PM   #5
SoNic_real_one is offline SoNic_real_one  United States
Windows has native drivers only for USB 1.1... That limits the audio to 2 channels, 16 bit, 48kHz.
For USB 2.0 you need drivers from the cip/card manufacturer. ASIO cannot provide that by itself. ASIO4ALL works with the WDM drivers so... it still needs drivers.
Are there also drivers for USB DACs?Hide this!Advertise here!
USB DACs with TDA1541? martinbls Digital Line Level 11 1st January 2010 07:26 AM
USB DACs and multichannel with x-over - is it possible Raj1 Digital Line Level 1 24th October 2008 10:04 PM
recommended usb dacs Ang Digital Source 13 1st June 2007 02:59 PM
Usb Dacs bjackson Digital Source 4 10th August 2005 10:14 PM
USB DACs again Adam Reed Digital Source 5 5th February 2004 08:00 AM
Copyright ©1999-2017 diyAudio
