Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th May 2011, 02:32 AM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Enable DS90LV031?
To enable http://www.datasheetcatalog.org/data...r/DS012625.PDF
Do I connect EN to ground and EN* to Vcc?
Old 27th May 2011, 04:14 AM   #2
prairiemystic's Avatar
Yes, EN to VCC or EN* to GND will enable the outputs. The MAX9124 datasheet has a bit more info as it's pin compatible with DS90LV031A
Old 27th May 2011, 08:03 PM   #3
Ryssen's Avatar
Thanks,IŽll red the datasheet.
Old 30th May 2011, 01:07 AM   #4
Ryssen's Avatar
Yes I found this picture,so I guess it is enabeld in this mode..
pair of Fostex fe126en with enable bigaudioscotto Swap Meet 2 25th April 2011 10:59 PM
EnABLE for golf balls? scott wurcer The Lounge 10 22nd November 2010 12:59 AM
RFE: Enable 'Tags' feature dfidler Forum Problems 1 14th August 2010 01:56 PM
enAble speakers on youtube xecluded Multi-Way 8 19th July 2010 02:55 AM
EnABLE progress. DonB Full Range 2 8th May 2010 01:29 AM
Page generated in 0.07650 seconds (71.31% PHP - 28.69% MySQL) with 10 queries
