DIY ADC around?
DIY ADC around?
Old 15th May 2011, 11:26 AM   #1
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Default DIY ADC around?
did anyone try and build a DIY analogue-to-digital converter that surpassed at least entry level and mid-priced solutions in soundcards or external studio gear?
I have the faint feeling that one might do better than that what's in my RME ADI-2. I have, however, rarely seen DIY-efforts in this area.
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 15th May 2011, 06:08 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
DIY ADC around?
The only one I know of: AD24QS and DA24QS - Audio ADC and DAC, 24 Bit / 192 kHz
/U.
Old 15th May 2011, 08:47 PM   #3
SoNic_real_one is offline SoNic_real_one  United States
Better than yours?
Dynamic range AD: 110 dB RMS unweighted, 113 dBA
THD AD: < -110 dB (< 0.00032%)
THD+N AD: < -104 dB (< 0.00063%)
Crosstalk AD: > 110 dB
You are dreaming...
Old 16th May 2011, 03:01 AM   #4
qusp is offline qusp  Australia
qusp's Avatar
yeah not a chance, you might be able to improve the analogue section of your rme somewhat, but the rme gear is pretty superb and rocksolid
Old 16th May 2011, 03:23 AM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
PCM4222EVM.
The appnote contains schematics and BOM for this, so you could DIY it. However its not a trivial exercise if you have no experience with low noise digital circuits. The typical ADC performance exceeds the specs that SoNic has quoted (123dBA dynamic range for example, THD+N -108dB). If you're really serious about performance you can do better still by designing your own digital filter rather than using theirs.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th May 2011, 04:01 PM   #6
qusp's Avatar
yes, the typical adc listed spec does, but typical real world performance may not be that easy. possible, but better to just improve the analogue section of what he has already imo, because adc real world performance will depend heavily on the quality of the mic-pre and analogue input section. then you also have the interface, software driver etc. the rme is renowned for driver stability, rugged build and as a bonus you can use it standalone
Old 16th May 2011, 05:00 PM   #7
Exactly. The specs are someting, implementation is where the truth is.
He might improve the input stage using better components, but that's it.
PS: Another product that has better ADC performance (for less money) is EMU1616:
Analog Line Inputs
Type: servo-balanced, DC-coupled, low-noise input circuitry
A/D converter: AK5394A
Level (software selectable):
- Professional: +4dBu nominal, 20dBu max (balanced)
- Consumer: -10dBV nominal, 6dBV max (unbalanced)
Frequency Response (20Hz-20kHz): +0.0/-.03dB
Dynamic Range (1kHz, A-weighted): 120dB
Signal-to-Noise Ratio (A-weighted): 120dB
THD+N (1kHz at -1dBFS): -110dB (.0003%)
Stereo Crosstalk (1kHz at -1dBFS): < -120dB Analog Line Outputs
Old 17th May 2011, 03:23 AM   #8
qusp's Avatar
yeah the emu stuf is good value, but the interface cant touch patchmix
Old 29th July 2011, 02:01 PM   #9
Frex is offline Frex  France
DIY ADC around?
Maybe mine ?
(You have probably not well used the topics search engine...)
Frex
Old 7th October 2011, 03:38 AM   #10
alexcount is offline alexcount  United States
Send a message via AIM to alexcount Send a message via Yahoo to alexcount DIY ADC around?
I just started a project dubbed the OpenNGADC, or Open Next-Gen Analog to Digital Converter.
The basic idea is to create an open source pcb around the Arda AT-1201, which spec wise betters any commercial ADC out there, or course this is yet to be heard. I am not one for numbers, but I do want to push the capability of the open diy audio community.
It offers DXD output as well as 256fs (12.288Mhz) Delta-Sigma, 1 or 6-bit. And a better DNR than pretty much any part out there, feel it's worth a shot, even if I can't find a single report online as to how it sounds.
Currently working on the gerber files, I want to develop this as a community project, just have to find someone willing to help.
The name was chosen just to have something unique, could do better, but there are more important things than a name.
-Alex
DIY DSD/DXD Blog
DIY ADC around?Hide this!Advertise here!
Anyone interested in a general purpose DIY SPDIF/USB/ADC/DAC interface board using th allanw Digital Source 4 27th July 2010 07:47 AM
DIY ADC/DAC with ADAT echosystm Digital Line Level 1 8th May 2009 10:34 PM
diy ADC marksk Analogue Source 1 5th July 2007 03:40 AM
DIY ADC info ? audiosteve Digital Source 21 24th March 2007 10:22 PM
Diy Adc Khron Digital Source 7 17th July 2005 11:45 AM
