XMOS-based Asynchronous USB to I2S interface
Old 19th February 2012, 02:30 PM   #401
Lorien is offline Lorien
WaveIO's I2S port is configured in 32 + 32 bit format. More infos can be found here starting from page 24.
Kind regards,
L
Old 19th February 2012, 03:01 PM   #402
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by regal View Post
I am surprised it helped the nfb-12, I have one but it measures high distortion (starts with -80dB 2H) stock. Was planning on adding an arudino along with the WaveIO with a new enclosure and better output stage. Glad this turned out good for you.
hehe wow that is epically bad for a dac! and a solid state one at that.
Old 19th February 2012, 04:19 PM   #403
Porfido is offline Porfido  Italy
Let's say that the Xmos vs NFB12 Tenor is a sure winner, but the Dac keeps its limits, that's for sure...
Does it really measure so bad?
I'm asking because others seem to report not so bad mesaurements:
http://supercurio.project-voodoo.org...-96k-24bit.htm
http://supercurio.project-voodoo.org...-44k-24bit.htm
http://supercurio.project-voodoo.org...192k-24bit.htm
http://supercurio.project-voodoo.org...amplerates.htm
http://supercurio.project-voodoo.org...upsampling.htm
Sorry, I realize I'm totally OT....
Old 19th February 2012, 08:54 PM   #404
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by hochopeper View Post
If Lorien or someone who knows the answer could answer this question about waveio output being 24+24 or 32+32 I'd be interested also.
This is found on page 29 (SPDIF):
The interface is normal channel with streaming built-ins (outuint, inuint). Data format is 24-bit left-aligned in a 32-bit word: 0x12345600
In the xmos refernce implementation the DAC cs4270/cs4244 is running 24 bits.
My conclusion is: the xmos chip runs the 24 bits format (24L+24R) in i2s.
By the way, the software description also says any i2s dac can be used:
Although the reference designs use the Cirrus CS4270/CS42448, any CODEC that supports I2S and can be used.
for me this is essential as this is the only way in which the board can be 'open', usefull for playing.
albert
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 19th February 2012, 10:12 PM   #405
regal is offline regal  United States
RightMark Audio Analyzer test : NFB-12 96/24
RightMark Audio Analyzer test : NFB-12 44/24
RightMark Audio Analyzer test : NFB-12 192/24
RightMark Audio Analyzer test: comparison
Yep same as I got. .015%THD ~ -77dB, mostly 2H.
Old 20th February 2012, 03:25 AM   #406
qusp's Avatar
worse than an ipod at 16/44 when operating at 24/192 now thats an effort
Old 20th February 2012, 07:00 AM   #407
sounds bad too
Old 20th February 2012, 07:52 AM   #408
Originally Posted by triode_al
In the xmos reference implementation the DAC cs4270/cs4244 is running 24 bits
Yes, because that DAC chip can't handle more than 24-bit resolution.
If you're referring only to the actual number of bits using for conversion then yes, WaveIO's I2S serial post could be considered to be 24L + 24R BUT, in fact it's 32(L) + 32(R) from which only 24 bits are effectively used.
Please see again this document at page 25 when it says:
p_sdin and p_sdout are configured as buffered ports with a transfer width of 32, so all 32 bits are input in one input statement. This allows the software to input, process and output 32-bit words, whilst the ports serialize and deserialize to the single I/O pin connected to each port.
... this statement can be found after Table 10:
In any case, the bit clock outputs 32 clock cycles per sample
.. and this will prove that it's a 32-bit/channel I2S interface:
p_lrclk is clocked by p_bclk. The port outputs the pattern 0x7fffffff followed by 0x80000000 repeatedly. This gives a signal that has a transition one bitclock before the data (as required by the I2S standard) and alternates between high and low for the left and right channels of audio.
Convert into binary the hex number 0x80000000 and count the bits.
Kind regards,
L
Old 20th February 2012, 02:36 PM   #409
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign XMOS-based Asynchronous USB to I2S interface
Lorien, news about the new board ?
Old 21st February 2012, 05:31 PM   #410
I've test your card today (at home) and it's working as expected though I must customize it and cleaned it up before sending to you. I have to wait few more days to feel better though... before getting back to work and send your WaveIO board.
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
