XMOS-based Asynchronous USB to I2S interface
Old 29th June 2014, 07:34 AM   #2101
Lorien is offline Lorien
Originally Posted by Nounours18200 View Post
SO you have connected the WaveIO BEFORE installing the driver...
As long as Thescyon installer want to "see" WaveIO at installation process, you have to plug in your card in any free USB ports. But right after you'll do that, Windows will attempt to search for compatible drivers for your WaveIO. In this time Thesycon installer cannot access your card and you have to wait until Windows will give up on what it's doing or... cancel the process. After that, things are going back to 'normal'.
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 29th June 2014, 02:22 PM   #2102
Nounours18200 is offline Nounours18200  France
Thanks Lorien, but I did not get the chance to see this (!) because the WaveIO card is not detected by my desktop PC (W7-64) nor by my notebook (W7-32).
The green LED of the WaveIO card is OK (it is on), but the card is not detected...
Any idea ?
Old 29th June 2014, 08:20 PM   #2103
Make sure J8 is on "BRD" position if you use the on-board USB-B connector. Please let me know if this is solving your issue!
L
Old 30th June 2014, 07:17 PM   #2104
NO: J8 is on the "EXT" position because I link the WaveIO card to a PC using the USB type B external connector, and I want to play music files from a PC, convert them using the DDDAC1794, and feed my preamp with the DDAC.
Unless I have misunderstood, the "BRD" position has to be used if the WaveIO is connected by the onboard pins, not by the USB connector ??? (but maybe I am wrong ?)....
EDIT : Well... by reading again the WaveIO documentation, it seems that I made a confusion ! I have to try again with J8 in the "BRD" position... i try and I keep you informed ! Thanks ...
Old 30th June 2014, 08:02 PM   #2105
Well things are improving : the J8 jumper is now on the "BRD" position, the WaveIO card has been recognized by the PC, the proper drivers have been installed.
BUT: no sound at all. The green LEDs "Host active" and "48kHz" are on, but the "Audio stream" LED is not on.
This let me believe that there is maybe a wrong cabling :
-between the USB card and the SPDIF/I2S card
or
-between the SPDIF/I2S card and the DAC motherboard
Any idea to search where the problem is located ?
Old 1st July 2014, 10:53 AM   #2106
fmak is offline fmak
Default Err No KS buffer in Spy Tool
Lorien
I found the attached Err entry in TSUB Spy Tool.
What is the significance of this?
Fred
Old 4th July 2014, 12:09 PM   #2107
or
Usually if the "Audio stream" LED is not on then there could be software issues related to your OS and player you are using on it. Have you managed to solve your issue?
Originally Posted by fmak View Post
Lorien
Fred
please give me details regarding the driver version you are using, what operating system, and on how many bits, what player and so on...
I'll forward your infos to Thesycon and ask them to answer to your question!
Thank you,
L
Old 4th July 2014, 12:34 PM   #2108
Default KS Err
Thank you,
L
Latest Driver 2.23 but also found in 2.15 etc
Win 8.1 x32 but also in x64
32 bit KS 50 and 140mS buffer foobar 1.3.2 KS driver with no plugins activated. Native 176.4 and 192k .wav files.
I would really like to get to the bottom of this. Does it happen in your systems?
Old 4th July 2014, 07:46 PM   #2109
I have used a notebook on Windows 7-SP1 32 bits, drivers version 2.23 and Foobar 1.23 as music player.
Can the cause be a cabling error between the WaveIO card / the SPDIF/I2S card / and the mainboard ?
Would you recommand to uninstall the drivers 2.23 and replace them by the version 1.6x ?
Old 7th July 2014, 09:15 AM   #2110
Stixx is offline Stixx  Germany
Stixx's Avatar
After I got my WaveIO card more than a year ago I recently breadboarded my Subbu ES9023 DAC with a JG Filter Buffer and their respective power supplies. Before I switched it on I installed the latest drivers on the Thinkpad netbook I am using as transport... et voilà... music from the first second.
And what a sweet music it is!! Compared to my previous setup that used a Hiface EVO converter with a battery supply this is a huge improvement ... in terms of detail, sweetness of treble and an almost holographic presentation!
Bravo Lorien!
www.original-ton.net
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
