XMOS-based Asynchronous USB to I2S interface
Old 29th November 2011, 04:33 PM   #201
flocchini is offline flocchini  United States
Default Synchronous Clocking
Can someone point to a place where I can learn about synchronous clocking?
I would like to set my XMOS board and Buffalo II up to do this and let my ears be the judge.
The more I listen to my set-up with the XMOS board the more I like it. I'm asking myself - "did I hear that before?" Lucian - great job
Old 29th November 2011, 04:53 PM   #202
barrows is offline barrows
Flo: do a search of the TPA B-II and B-III forums. You will find everything you need with a little research.
Old 29th November 2011, 05:06 PM   #203
Lorien is offline Lorien
rol, can you be so kind to provide details on how you wired your WaveIO card to Buffalo DAC?
Thank you,
L
Old 29th November 2011, 06:14 PM   #204
Will do
Old 29th November 2011, 06:18 PM   #205
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by flocchini View Post
Will do
and do please report back!!!
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 29th November 2011, 06:26 PM   #206
I do move move slow these days (you young guys move at the speed of light) but I will report what I find.
I did notice in the Buff III integration manual the use of synchronous clock is discouraged. Just a note but not a deterrent.
Best
Old 29th November 2011, 06:30 PM   #207
labjr is offline labjr  United States
Best
Maybe because it's more difficult to implement. However, I would think it's the best way to go if you're up to the task.
Old 29th November 2011, 06:31 PM   #208
Thank you,
L
In my set-up I used micro BNC on the WaveIO side and bare wire on the BII
Data and GND were obtained from same cable and connected to D2 and GND on BII
BCLK was connected to DCK
LRCK was connected to D1
Buffalo was set to accept I2S
Installed Drivers Lucian sent on my MAC
Best
Old 29th November 2011, 07:22 PM   #209
reo is offline reo  Canada
Do remove the Trident from the Dac's VDD_XO circuit. If you don't have the Trident on your Dac then simply remove the ferite bead that controls the VDD_XO which is located on the underpad (L8)mmm not sure it's that one so follow the trace.... which should disconnect the onboard Crystek .
Now locate your R17 pads on buffaloII ? when looking at the Dac with the twisted pear logos facing upright., you locate the right pad from the 2 R17pads to connect your MCLK live wire only, from WaveIO, then you use the ground wire from your MCLK and connect to left pad of R17 .All your I2S connections from WaveIO to buffaloII will be as short and similar lenght as possible .
hope that helps to synchronize and do convey your results please .
regards
rol
Old 29th November 2011, 07:53 PM   #210
Thank you rol!
L
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
