XMOS-based Asynchronous USB to I2S interface
Old 25th June 2013, 10:16 AM   #1811
JensH is offline JensH  Denmark
Unfortunately the phase relationships between the master clock and the other clocks are not specified in the data sheet. But since it is claimed that it works, even with a master clock, which is not synchronized at all with the other clocks, I would also assume that the phase of a synchronized clock is not critical. There should be plenty of possibilities to reclock the slower signals internally to also avoid the risk of metastability.
For other DAC's it is clearly specified. Here are a couple of examples:
CS4398:
MCLK can be at any phase in regards to LRCK and SCLK. SCLK, LRCK and SDATA must meet the phase and timing relationships outlined in Section 2.
PCM1794A:
The PCM1794A requires the synchronization of LRCK and the system clock, but does not need a specific phase relation between LRCK and the system clock.
Old 25th June 2013, 12:35 PM   #1812
m.massimo is offline m.massimo  Italy
Default Arduino lcd for WaveIO
I implemented the lcd display idea of Doede posted in this thread some days ago (and fully described on his website DDDAC site) based on Arduino Uno and 16*2 lcd.
It's easy to build, affordable and customizable. You can show any message you want, provided a very basic knowledge of programming code.
I was comfortable with leds, but this is really fine.
If anyone is interested in building it and need some help or advice, feel free to ask.
Thank to Doede for the input.
Old 25th June 2013, 12:53 PM   #1813
barrows is offline barrows
Default qusp...
Originally Posted by qusp View Post
actually barrows, all info i've seen oft' repeated and from my own experience, its the opposite, inverted Mclk. thats why this was provided as the default on the fifo Si570 board (though you can choose)
Thanks for that info. You can confirm that the masterclcok needs to be exactly 180 degrees to bit clock for synchronous clocking of the ESS 9018?
I know the ESS DAC will work with masterclock not synched to bit clock, but my understanding is that doing this will allow the ASRC and DPLL to become active-the entire reason I, and others, want to synchronously clock the ESS is that we want to make the ASRC and DPLL idle, because we do not want the DAC to re-sample the data asynchronously. Using an out of sync MC would defeat the purpose of synchronous clocking as I understand it-If one is OK with the ESS' onboard ASRC being active, then one can just go ahead and provide an independent 80 MHz-100 MHz masterclock for all sample rates and be done with it, but my experience is that synchronous clocking sounds better given a low jitter source.
Is Dustin (ESS designer team member) still active here? Lucien, you could try sending Dustin an inquiry via PM here.
Old 2nd July 2013, 02:22 PM   #1814
orangeart is offline orangeart  United Kingdom
I am currently building an active crossover setup with the miniDSP mini sharc and need to fix the sample rate to the 48Khz i2s input of that board. Is there a way of forcing the waveio to output a fixed sample rate or is it always going to pass the sample rate of the file it is given?
Old 2nd July 2013, 02:43 PM   #1815
Default Lucien, update
I have heard from two reliable sources now, that for synchronous clocking of the ESS 9018, the master clock and bit clock need to be synchronous, but that inverted phase as mentioned above is not necessary. I consider these sources trustworthy (one is a manufacturer who makes ESS based DACs, and produces their own USB interface). Apparently Dustin from ESS has mentioned that there may be a performance advantage to having the rising edge of the master clock signal aligned with the falling edge of the bit clock signal; but no one appears to have observed any actual advantage from doing so.
Old 4th July 2013, 11:32 AM   #1816
Lorien is offline Lorien
Well, there was a case when I had to change the base firmware and allow the card to work with 44.1 & 48 Khz sample rates. At that time I forced the WaveIO to report maximum sample rate to be 48 Khz @ USB enumeration. Any higher fs tracks than 48 will force the player to report an error/warning. I guess I could do that for you too.. free of charge, of course
@ barrows: Thank you and thank you! I didn't managed to talk with Dustin but I guess things are quite settled for now... I'll see what path do I have at disposal to implement all the MC/I2S clock requirements.
Thank you again,
Lucian
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 4th July 2013, 04:31 PM   #1817
Hi Lucian, That could work but the sample rate need to be fixed rather than allowing anything bellow (x)Hz through.
I guess there is no way of Implementing ASRC code with the waveio. I ask as there does seem to be some XMOS implementations out there specifically working as an ASRC.
Cheers
Stefan
Old 5th July 2013, 08:18 AM   #1818
soundcheck is offline soundcheck  Germany
Hi there.
Has anybody replaced an SPDIF coax output with Toslink on the WaveIO??
Cheers
Old 5th July 2013, 08:34 AM   #1819
Lorien.
I know you're busy with squeezing the last 0,2% of quality out of your product.
I'm wondering if you finally considered to go multichannel I2S or SPDIF?
Multichannel SPDIF in particular. There is no such interface in the market.
The USB Streamer from MiniDSP comes with 8 channel I2S. But that would require an I2S to SPDIF interface to be build. And I'm wondering how that USB streamer would compare in quality to your interface.
Many people could replace stuff like Behringers, MiniDsp Nano Digi asf. and use existing DACs, full digital amps etc. and use the PC as DSP which much higher flexibility and performance then MiniDSP products.
Subwoofer integration could easily accomplished. Multichannel and speaker activation would be much easier.
Cheers
Old 5th July 2013, 08:37 AM   #1820
Soundcheck, if you were to got this route, what software would you be using to do the realtime crossover / dsp ?
Stefan
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
