XMOS-based Asynchronous USB to I2S interface
Old 24th February 2013, 06:53 AM   #1661
henry97 is offline henry97  United States
Originally Posted by Lorien View Post
Hello Proktos,
the list is updated here, per your request, thank you!
L
I also interested, and Just adding the list. Thanks.
Old 24th February 2013, 09:12 AM   #1662
Lorien is offline Lorien
Originally Posted by Klim View Post
@Lorien:Thanks! WaveIO- very good sound, stable device.
No problem about gallery.
One question about samplerate settings in control panel (WIN 7)
Regardless of the frequency of the playing file output format remains the same as defined in the device settings. Hence, resampling occurs means the operating system kernel? Or the driver? How can I make the output bitrate automatic switch would be match the playing file bitrate?
p.s. sorry for my bad English :^)
Is the sample rate 44.1fs? Are the sample rate LEDs on WaveIO reflecting any changes? What type of Win player do you use?
Thank you for your kind words about this board! Your pictures will be posted on WaveIO's site today.
L
Edit: @ henry97: noted, thank you!
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 24th February 2013, 11:41 PM   #1663
kp93300 is offline kp93300  Malaysia
Default dsd files
Hi Lorien,
can i play dsd files via the waveio with linux or window7 OS ?
Do i need to made any changes in the wiring with dsd files when compared to i2s ?
Sorry if this has been answered before.
thanks
kp93300
Old 27th February 2013, 06:30 AM   #1664
Well, DSD is still in my "TODO" list as my wish for now is to finish the project I'm working on (@ hardware level) and be back to update the firmware of all the WaveIOs I've made so far.
L
Old 27th February 2013, 09:41 AM   #1665
lindamar is offline lindamar  Spain
Location: Madrid - Capital of the Kingdom of Spain / European Union
Hi Lucian,
do mean by any chance that DSD reproduction is only a matter of a firmware upgrade ?
best regards
Pepe
Old 18th March 2013, 08:25 AM   #1666
fmahia is offline fmahia  France
Hi, I'd just like to know if it's possible to have 2 waveio running at the same time?
For the moment I have 2 different interfaces (included 1 waveio) to drive my multi-amp speakers with a PC software digital filter and I'd like to have 2 waveio.
Old 19th March 2013, 10:43 AM   #1667
Chii is offline Chii  United Kingdom
Lorien have added my self for one + DB.
Old 19th March 2013, 09:03 PM   #1668
mxb is offline mxb  Australia
I am running 2 x WaveIO's simultaneously on a Linux based system., so it is possible.
Old 24th March 2013, 09:26 AM   #1669
triode_al is offline triode_al  Netherlands
triode_al's Avatar
A lot of talk about I2S to TDA1541
But how about PCM56, as I have some in old sony players
Can this be connected with a single inverter like Bernard informed (this is exactly what is used in both Sony players . . .), or should a more elaborate setting be used because of inter-channel delays?
fyi: I currently have a CS8412 DAC no XMOS yet
welcome to some thoughts
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 25th March 2013, 10:06 AM   #1670
triode_al's Avatar
Or, Lorien,
I understand you are making a reclocker = the daughterboard.
is your reclocker extension going to provides a synchronized LE and inverted-LE that allows attaching a PCM5*, PCM6*? That would solve my problem (I am currently contemplating a ready-made reclocker to do the trick).
albert
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
