XMOS-based Asynchronous USB to I2S interface - Page 166 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th February 2013, 06:18 AM   #1651
Hi Lucian, is a google account mandatory in order to access the list?
In that case a mirror on your website could be a good idea.
Old 12th February 2013, 07:18 PM   #1652
Hello Massimo,
no, Google path was chosen to be a simple way for all of us but I'll try to find a solution in the following days and, if possible, move the list on WaveIO's web site. Thank you for the idea, it's highly appreciated!
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 13th February 2013, 03:42 PM   #1653
What is the price of the waveIO group buy?
Old 14th February 2013, 01:19 PM   #1654
Hello and sorry to all members here on this board, because, I did not read all comments in this thread yet, and it could be, that my question is mentioned before.
Want to buy the Wave I/O board, but I have to know if the board, software and all needed drivers are running under Windows 8? And how long is the delivery time?
Greetings Rainer
Old 15th February 2013, 07:42 AM   #1655
That group buy is for the Daughter card (in development) but can be purchased with a WaveIO for all that does not have one already. As for prices, are unknown so far but will be available when I'll finish it. Thanx!
Greetings Rainer
Hello Rainer, you have PM but it comes a little bit late, I'm sorry as I had to solve some personal issues and this ruined all my plans with dispatch dates. Given this, it becomes longer than posted on WaveIO's web page but I'll work close to catch it up from behind.
Thank you for understanding, L
Old 18th February 2013, 12:27 AM   #1656
Default USB Streaming Mode
Hi Lorien:
I am sorry if the question has been already asked and answered but please help me understand a setting in driver's control panel
USB Streaming Mode
Minimum latency
Low latency
Standard
Relaxed
Extra Safe
Do these settings only relate to buffer size? Any effect on USB streaming/clocking? Do these settings affect jitter at all? Please write in detail.
Old 18th February 2013, 10:25 AM   #1657
triode_al's Avatar
Originally Posted by deduikertjes View Post
I've tried with 5v (datasheet of the isolator specifies a max of 7v). No sound ...
Trying onlyone dac chip is very difficult. I can't easily take one out of the tower.
Or would it be enough to remove the power supply to 7 of the 8 dac chips?
Is there a way to measure if levels to the dac chips are ok? I don't have a scope ...
Thanks, marco
Setting up TDA1543 towers is tricky on itself (adjusting both V+ and the Rref, and settling for the non-clipping point). During most settings I tried it failed, even failed for no reasons at all (i understood) and sometimes haphazardly.
  • Did the tower work in a different setting (CD player for instance); i did not see you mentioned that.
Of course remove power of chips is OK to start; but then you need approx. an 8x as high Rref to get the same Vref...
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 20th February 2013, 06:02 PM   #1658
Klim is offline Klim  Ukraine
Klim's Avatar
Hi! This is my implementation based on the WaveIO and ArpeggioT2 DAC
Old 22nd February 2013, 03:17 PM   #1659
@ new2hifi: I've forwarded your question to Thesycon as I don't know how that Control Panel was designed nor knowledge about how it works. I'll post their answer right after I'll get it.
@ Klim: very nice project you have there! Can I post them on luckit.biz @ Gallery section?
L
Old 22nd February 2013, 06:29 PM   #1660
Klim's Avatar
@Lorien:Thanks! WaveIO- very good sound, stable device.
No problem about gallery.
One question about samlerate settings in control panel (WIN 7)
Regardless of the frequency of the playing file output format remains the same as defined in the device settings. Hence, resampling occurs means the operating system kernel? Or the driver? How can I make the output bitrate automatic switch would be match the playing file bitrate?
p.s. sorry for my bad English :^)
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1375 4th March 2017 07:58 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Copyright ©1999-2017 diyAudio
