XMOS-based Asynchronous USB to I2S interface
Old 17th November 2012, 09:53 AM   #1451
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Originally Posted by qusp View Post
sort the ground loop out, shield one end is not terribly effective
So you're saying to connect both ends?
CE-Designs.net
Old 17th November 2012, 09:58 AM   #1452
hochopeper is offline hochopeper  Australia
For a u.fl cable, connect both ends. This provides a return path for each signal wire.
For a USB that has +/- power and +/- data and shield then the shield should connect at the usb connector casing on the host end only.
Old 26th November 2012, 04:00 PM   #1453
shumgary is offline shumgary  Hong Kong
Hi Lucian
1. How can I update the firmware if my device is still at rev ID 0x0330?
2. I tested the WaveIO board today using SPDIF. it worked fine at the beginning but it come out noise. How can I do the troubleshooting?
Index VID PID REV DFU supported USB mode
00 0x20A0 0x4143 0x0330 no APP
Gary
Old 27th November 2012, 07:28 AM   #1454
Lorien is offline Lorien
Hello Gary,
1. as you probably figured out by now, only WaveIO cards with revision ID of 0x0331 or newer can support DFU updates. For all older ones, the firmware in local EEPROM must be changed accordingly by using an EEPROM programmer thus you have to send back your board here to make the appropriate changes. After that, any future firmware released will be on a few clicks away from you.
2. With your approval, I'll contact you through email to keep this thread clean.
Kind regards,
L
@shumgary: you have PM.
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 30th November 2012, 05:11 AM   #1455
CKL is offline CKL  Hong Kong
My clicking noise problem is solved by replacing the U.FL cables.
Old 30th November 2012, 11:13 AM   #1456
audiosm is offline audiosm
I have added into the daughter board list. My mpdpup now with mpd ver 17 sounds great already with the WaveIo, but more improvements cant be resisted.
Old 1st December 2012, 04:59 PM   #1457
staki is offline staki  Switzerland
I added myself to the spreadsheet for one daughterboard (number 89), although I don't have any WaveIO card for now. I have ordered one, and after having read all the positive opinions on this thread (146 pages !! ), I am impatient of being able to use it !
btw, I see that hirez69 has been deleted from the first position on the spreadsheet. Is it an accident ?
Cheers, staki
Old 3rd December 2012, 07:57 AM   #1458
@ audiosm and staki: Noted, thank you! As for the issues reported... were corrected! As the list is open for everyone I cannot add restrictions nor I do want to. Anyway, for back-up cases, I keep a copy of it somewhere on my laptop incuding some sensitive informations that wants to be kept private
Is it an accident ?
From what I can recall, there were 2 or 3 "accidents" so far, all involving only one user: hirez69. I doubt he want to be out of the list as I know him quite well... but I'll send a private message and ask for details (if any).
Kind regards,
L
Old 3rd December 2012, 08:17 AM   #1459
Kind regards,
L
Maybe some people delete his name by error, because when they arrive on the spreadsheet they first add themselves on the first position. After that they see that they must go to the end of the list, but they forget to rewrite hirez69 again.........
I don't know, just an assumption.......
Cheers, staki
Old 3rd December 2012, 08:30 AM   #1460
Dear Lucian,
I have a question regarding the i2s output. If one wants to use a double mono configuration, with two dac chips, is the i2s output capable of driving two dac chips in parallel ? I suppose it is a question of fanout, and perhaps isolated or not isolated outputs........
Cheers, staki
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
