XMOS-based Asynchronous USB to I2S interface
Old 14th November 2012, 11:07 PM   #1441
hochopeper is offline hochopeper  Australia
Originally Posted by wlowes View Post
Basically if it is working reliably as shipped, is there any reason to bother with the new firmware?
My understanding is that the *only* change is the way the WaveIO identifies to the USB host. The sonic benefit may come by being able to use a lower power (potentially less noisy) PC for the USB host.
Old 16th November 2012, 02:55 AM   #1442
Kazuo Ozawa is offline Kazuo Ozawa  Japan
Kazuo Ozawa's Avatar
I have just put my name in the WaveIO daughter board list.
Thanks.
Old 16th November 2012, 06:17 AM   #1443
Lorien is offline Lorien
Originally Posted by Magsy View Post
Yeeeha!
Working on iPad 2,4 and Mini without any issue, plug it in and it sounds beautiful. Still works on the PC fine too
Only one thing, I don't have dfucons and it is not in either driver on the website, so currently I cannot factory default. Can you please zip that and put it on the website?
Thank you very much!
The archive was made but wasn't uploaded. It's solved now thus you can download the dfucons tool now. I guess you took the other path to upload the new firmware by choosing the appropriate option in the TUSBAudio Control Panel. Unfortunately it cannot reverse it to defaults hence my recommendation for dfucons alternative.
Thanks.
Noted, thank you!
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 16th November 2012, 10:28 PM   #1444
Magsy is offline Magsy  United Kingdom
I thought once I flashed it, it wouldn't work bus powered anymore (without reverting to defaults). However I am listening to it right now powered by the PC and I haven't done anything....so that's cool, the one firmware is good for both.
Thanks for dfucons!
Old 17th November 2012, 05:18 AM   #1445
I thought that too even so I don't think that all PCs/MACs will act the same... I still prefer to change the descriptors accordingly, just to be in "USB specs"
Best wishes,
L
Old 17th November 2012, 09:30 AM   #1446
Corpius is offline Corpius  Netherlands
Corpius's Avatar
When using shielded cable for the I2S connection, does the shield need to connect to GND?
CE-Designs.net
Old 17th November 2012, 09:33 AM   #1447
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If you want that the shield be active, yes in both ends or only in the load end.
Old 17th November 2012, 09:39 AM   #1448
Corpius's Avatar
In that case I prefer to connect just one end to avoid ground loops
EDIT: Should I connect it to the GND at the WaveOI or the other end?
CE-Designs.net
Old 17th November 2012, 09:45 AM   #1449
I do the same and always only connect the load end (Erno Borbely advice).
Old 17th November 2012, 09:48 AM   #1450
qusp is offline qusp  Australia
qusp's Avatar
sort the ground loop out, shield one end is not terribly effective
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1400 19th December 2017 07:46 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
