XMOS-based Asynchronous USB to I2S interface - Page 143 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd November 2012, 09:12 AM   #1421
For J12 and J6 (LEDs and I2S) you can choose any 10-pin IDC connectors like these ones:
* AWP-10 NINIGI - Muf? | Transfer Multisort Elektronik
* AWP-10B - Muf? | Transfer Multisort Elektronik
* 09185106803 HARTING - Muf? | Transfer Multisort Elektronik
... and list can go on.
Below you'll find a part of Farnell's offer:
Your Search Results | Farnell România | Results
As for external power, I guess two thick wires and a screw driver will solve your little dilemma
Lucian
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 2nd November 2012, 09:29 AM   #1422
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
And is there a pdf file that shows all the headers?
Regards Åke
Old 2nd November 2012, 09:52 PM   #1423
Sandor is offline Sandor  Italy
Lucian, thanks a lot.
Have you a recommendation for the cable?
Is soldering required?
Sorry for the silly questions, I've never used either those IDC connectors or flat cable.
Old 2nd November 2012, 10:02 PM   #1424
Ryssen's Avatar
When you(I) order the WaveIO ,does it come witj any documetation how to connect all this headers?
Regards Åke
Old 3rd November 2012, 07:07 AM   #1425
@ Ryssen: You can find some pdfs at www.luckit.biz => Support section. That will also be emailed to you when I'll give you the tracking number of your parcel.
@ Sandor: If you have a 40-wire PATA ribbon cable used for Optical drives or HDDs then you can use it for your connections. Seems that I can't find any suitable video on youtube that shows you how to use IDC connectors with ribbon cables. I'll continue searching and email the link if I'll find any.
L
Old 3rd November 2012, 10:06 AM   #1426
Ryssen's Avatar
Ok,thanks.
Regards Åke
Old 3rd November 2012, 10:38 AM   #1427
Ryssen's Avatar
It says to use Leds with 8mA current draw,if I use with around 20 mA that is the most common,will I overload sommething on the board then?
Regards Åke
Old 3rd November 2012, 11:52 AM   #1428
Add a resistor to limit the current, I use a 5k for each led
Old 3rd November 2012, 12:06 PM   #1429
Ryssen's Avatar
Ok,I´ll do that.
Regards Åke
Old 9th November 2012, 05:58 AM   #1430
CKL is offline CKL  Hong Kong
Hi Lorien,
I have no problem with the SPDIF and the isolated I2S outputs. Now when I connect to the non-isolated I2S output with the U.FL mini BNC sockets, there is a strange problem. The sound has become garbage 'after a while'. I have to remove the 5V power and 'wait for a while' to resume.
Note: I have de-soldered the external 3.3V power to the isolated I2S as I use the non-isolated now.
Thx
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1375 4th March 2017 07:58 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Copyright ©1999-2017 diyAudio
