XMOS-based Asynchronous USB to I2S interface
Old 1st November 2011, 06:09 AM   #131
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by barrows View Post
I do know that RF phobic designer Charles Hansen of Ayre uses optocouplers for the I2S lines from his USB receiver to DAC board in the QB-9 USB DAC, despite the fact that the optocouplers themselves will add some jitter.
Its possible therefore that Charles Hansen, like me, considers common-mode induced noise more of a problem to audio quality than jitter.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 1st November 2011, 06:23 AM   #132
rsdio is offline rsdio  United States
Originally Posted by Turbon View Post
If it's a 1 it should show itself as a 1 and if it's a null it should show itself as a null. Otherwise it's a bug...
You've only discussed one of the two variables. Timing is also a variable. It's probably safe to assume that I2S rarely or never has a bug such that a bit value is flipped. However, moving even a single sample in time due to jitter has exactly the same result in the analog domain as changing its PCM code. These discussions are basically 100% focused on clock timing and reduction of jitter. Timing is not critical over USB, assuming that asynchronous delivery of the data is accomplished properly. However, I2S is probably the only place where the clock data must be perfect, or as close to perfect as possible, for the best DAC performance.
While we're on the subject (and I hope it's not distracting from the main thread), is it typical for an I2S source to be the master clock, or is it possible for an independent clock on the same board to be the master of both the XMOS FPGA and the I2S slave? In other words, could the DAC be the master clock so that the XMOS FPGA is a slave rather than the source of the timing?
Old 1st November 2011, 06:28 AM   #133
abraxalito's Avatar
Yes I2S is really defined as only 3 wires - BCK, DATA, WS. Oftentimes an MCLK (typically 256fs) is sent as well. In all cases the sender is clock master.
There's obviously a need for another protocol where the receiver is clock master - other than asynch USB (which is way complex) I'm unaware of any standard one.
Old 1st November 2011, 06:35 AM   #134
Turbon is offline Turbon  Sweden
Turbon's Avatar
rsdio.
If timing alters the values of the stream it's definetly a bug or a collateral descision that it doesn't have any inpact on the listeners experience proven by the success of lossy formats..
Now, put it this way. If the sender sent a 1 and the receiver intepreted it as a 0 does the industry (we?) have a serious problem to deal with?. Now, does it sound bad if there is a bit misinterpreted here or there within every second? Of course bit perfection thru all domains is possible asyncronous - your amp won't play before all bits has arrived. Now, how would it know? Well, of course it can have a md5 sum with every byte and so forth to assure true fidelity... Will it sound better?
Of course I share an idea of reducing the multitude of errors in my signal chain.
Brgds
Old 1st November 2011, 06:48 AM   #135
If timing alters the values of the stream it's definetly a bug.
It seems like you don't understand what I am saying. Timing does not alter the digital value. It doesn't even alter the analog value at the point in time at which the DAC converts the digital value to an analog value.
However, if you place the exactly correct analog value at a slightly incorrect point in time, the end result is indistinguishable from changing the analog value, and thus exactly the same as if the digital value has been changed.
I've proven this for myself. Beyond just reading about it in the textbooks, I have designed DAC circuits (operating at sample rates as high as 6 MHz or even 125 MHz), and it is clear that the noise floor increases when the clock timing is altered via jitter. This can be confirmed with an independent ADC to measure the quality of the analog waveform that was produced.
You are correct that the I2S stream should never be altered, and if it is altered then something serious is wrong. However, even if your criterion is met, and the I2S bit stream is perfect, there is still plenty of room for 'errors' in the resulting continuous analog waveform due to clock timing. That's what people are talking about here.
Old 1st November 2011, 06:59 AM   #136
I guess I'm thinking outside the box a bit. I2S is clearly those 3 signals, but who's to say where each of them come from? The XMOS FPGA is completely programmable, so it could be easily altered to be a slave to the BCK. However, I suppose my ponderings are moot, since we're not likely to find a DAC chip that provides BCK as master.
That said, it still seems possible that a standalone DAC board could have a local oscillator that is separate from the DAC chip. This local oscillator would directly drive the BCK pin on the DAC, and also be provided over the I2S connector for the XMOS (or other) FPGA to slave to. Perhaps this is a really dumb idea, because it would not be a standard that interoperates with anything already out there in the I2S world. But it sure would have the potential to work quite well in those combinations where both the data source and DAC boards agreed on the clock source.
In that realm - a standard bus - there is also FireWire audio. There are quite a few audio interfaces which are self-clocked, and use bidirectional communication with the media source (usually a computer) to pull audio sample data over FireWire with the DAC as the master clock. I'd love to design such a thing, whether it has I2S output or an on-board DAC, but the FireWire specifications are not freely available like USB. It's even rather difficult to find a complete list of which FireWire specifications are necessary to implement Audio.
Old 1st November 2011, 07:09 AM   #137
abraxalito's Avatar
Well I believe I2S does say, but if we venture outside the box as you're doing then sure, it makes more sense for longer distances if the DAC were the master. The problem then comes if we have multiple DACs, coz then its impossible to sync them without ASRCs. I think about designing digital XOs so more than two channels is an issue for me
XMOS isn't an FPGA as such but yeah I'm sure it can be programmed to be slave. I've been thinking about programming a much simpler device than an XMOS to handle this kind of functionality, making a DAC into a clock master. XMOS is a bit power hungry for my liking. I shelved the idea though when I began to consider all the synchronization issues for multiple channels and how to handle all the possible sample rates.
So long as one such board is enough, to hell with whether its a standard or not. Do you think nobody will never want more than one such board in a system?
Old 1st November 2011, 07:11 AM   #138
Continuing on with my crazy ideas (and begging the pardon of anyone who sees this as off-topic), maybe there is a way to do this without completely violating the I2S standard.
Imagine a stand-alone DAC board with I2S input for the DAC and I2S output that is fed by a local, on-board master clock. A newly-designed USB to I2S interface could also have a pair of I2S I/O connectors along with the ability to configure the clock source.
In the ideal setup, the DAC PCB would have its on-board master clock wired directly to the DAC with the lowest-possible jitter. This clock would also be buffered and send back to the USB PCB via an I2S output (the DATA would be empty: all 0). Meanwhile, the USB PCB would be designed to slave to the incoming BCK and WS that is coming from an I2S input port on the USB PCB (connected to the I2S output port on the DAC PCB). The XMOS FPGA would use the timing information coming from the DAC board to control the USB asynchronous data flow, and would also use it to control the timing of the I2S output that feeds audio sample data to the DAC board.
Admittedly, there are a couple of weak spots in such a design. For one, the XMOS would have to be running slightly ahead of the clock so that propagation delays between boards and chips do not result in errors.
Another problem is that it would be tempting to have configuration switches so that this system would also be compatible with standard I2S links, but any such switches would probably introduce jitter and make the whole exercise moot. In this respect, I think such a design would have to be dedicated to having the DAC board be master clock always.
Personally, I'd much rather have total control over everything, and combine the USB or FW interface on the same board as the DAC chip, so that the DAC clock could be the master for everything. But I realize the advantages of having a generic standard so that one USB board can drive multiple DAC boards, or one DAC board can be driven by multiple data sources. I just wonder whether this DIY community has the wherewithal to come up with a 'standard' for DAC as master clock that could encourage a small community of interchangeable boards.
The only reason I'm mentioning these ideas here is that it seems like a small revision to the XMOS board that this thread refers to could be made to support such a clock design.
Thoughts?
Old 1st November 2011, 07:11 AM   #139
Turbon's Avatar
I would say that firewire is dead from the industrys point of view. No interest - no money.
I do understand what you are writing rsdio but to be able to hear the timing imperfectness you need a constant error in your data chain. It can't show itself as something happening here or there.
Finally, don't worry about violating the standards as they have 2 sides. The lesser thought of is that it keeps you boxed so that you can't perform better than your competitors.
Brgds
Old 1st November 2011, 07:24 AM   #140
Thank you for specifically mentioning multichannel. I am also very interested in surround and biamping, or even both at the same time! In my mind, when I consider such things for myself, I envision a single board with everything local, and thus the master clock is still local to all DAC chips.
For a while, I had a 16-channel system in a public space that I was slowly building out, I had 4.2 surround working without biamping, but I was hoping to eventually reach 9.2 surround with as much biamping as I could fit into 16-channels (also limited by my budget for amplifier channels). But this was based on FireWire Audio with 8 locally-clocked DACs and 8 externally-clocked DACs (the latter for the less-critical channels like maybe the subs).
I only mention the XMOS out of my own (misguided?) sense of politeness to the OP. There are many potential ways to solve this. In fact, if there is a better thread to discuss these topics, please point me in the right direction.
Right. One board is always going to perform better. I am continually reminded of something from the white papers of Dan Lavry of Lavry Engineeering: There is no external clock that can out-perform a properly-designed internal clock.
I do sometimes hope that a small community can get costs down by designing bus-based interfaces (FW or USB) and standalone DAC boards with 'standard' interoperable interface protocols, but perhaps there are just too many quality tradeoffs in that approach.
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
