XMOS-based Asynchronous USB to I2S interface XMOS-based Asynchronous USB to I2S interface - Page 137 - diyAudio
Old 14th October 2012, 12:17 AM   #1361
rondadon is offline rondadon  Germany
Oh. I saw that the buffalo III costs about 300eur..That is way to much for me to spend on a dac. I think I should go with waveIO v2 + ES9023 subbu dac.
Do I need to only connect them over I2s and that's it or do I need to configure or program something on the boards?
And could I connect maybe a adc for a Mic also to the WaveIO through I2s or is this impossible?
thank you in advance. I am still on time with the subbu dac group buy..
only need to wait for the improved waveIO..
Greetings and happy listening....
Old 14th October 2012, 08:48 AM   #1362
luxury54 is offline luxury54  Romania
Hi, I see that this device has onboard X-tal oscillators being able to provide MCLK for an extrenal DAC;
but my question is, could this device be configured as a slave to an existing performant master clock that is placed near an external DAC so that this external clock provides the 11.2896 Mhz to the board, actually slaving to it the board and the transport (the PC)?
In affirmative case does one need to remove the existing XO from the board and connect the external clock in the same place, or is there a connection pin available and a jumper that could bypass the already mounted XO?
Thanks.
== There are no limitations to the self except those you believe in ==
Old 14th October 2012, 10:41 AM   #1363
Lorien is offline Lorien
Originally Posted by rondadon View Post
hi there. Tanks For your answer. I can wait a little bit. Is there a releasedate available for the rev2 board?
will it be much more expensive then the current revision?
Hello rondadon! Thing could be confusing here if you are speaking about WaveIO rev2 board so let's put it this way: WaveIO rev2.0 (or WaveIO next revision - without any specific number) will have to wait to show up and as I can see my schedule, I'm strongly sure that it will pass more than "little bit" (no offense!) to show up. SO, let's exclude it for now.
There are two chances for you:
1. is to buy actual WaveIO offer and wait for the daughter card to show up to improve its functionality or
2. wait (hopefully a little bit ) for the daughter card to show up and take them as a bundle.
I personally prefer to choose what is *real* so option 1 would be a good start for you. As a side note: you could also add DB to your WaveIO card later on... that's what all peoples from that list are waiting for (- with few exceptions), just need to place your name there to take the benefit of this GB.
Forgot to say: this WaveIO card is for playback only so you cannot add ADCs to it.
And is there any Idea to make the waveIO 6channel compatible? eventually with an extension board? This would be awesome...
No ideas, just plans
Thanks.
It's one of the DBs functionality (and my future task). Wait for it please.
Kind regards,
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 14th October 2012, 11:10 AM   #1364
thanks for your quick answer, then I'll wait for option nr. 2, so I could buy the actual board + DB together as a bundle
Old 14th October 2012, 02:52 PM   #1365
Kind regards,
L
Thank you for your answer.
So you say that the "next revision" waveIO would be the current board with the daughter board in one "delivery" . So all those who had ordered or who have the current waveIO Board til now will get this daughter board and there will be NO difference to the "next revision" waveIO Board?!
Or are you planing to change something directly on the waveIO board for the next revision?
If there will be no difference between the current version with daughter board and the "next revision" then I think It would be the best to order now!
Thank you in advance!
Kind regards
Ron
Old 14th October 2012, 07:55 PM   #1366
carsten.witt is offline carsten.witt  Germany
carsten.witt's Avatar
Lucian,
Can i use the i2s and the the spidf output at the same time for testing two dacs?
I want to make listening session between a Pass D1 Clone (from Spencer) and my mojo2.
Old 15th October 2012, 02:59 PM   #1367
@ Luxury54:
List is updated:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
42. 43. 44. 45. Mats x 4
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
62. & 63. Claudius J. x2
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
Kind regards
Ron
For the moment WaveIO is sold as is and later on with daughter card when it will be available. This bundle will exist as long as the new WaveIO is in development and will reach end of life after that. There will be some differences between the two WaveIO boards but the output stages will be identical.
Originally Posted by carsten.witt View Post
Lucian,
Yes you can, enjoy
Kind regards,
L
Old 15th October 2012, 03:07 PM   #1368
thanks, "a little showdown".
Old 15th October 2012, 03:16 PM   #1369
mjock3 is offline mjock3  United States
Default Please add me to list
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
Old 15th October 2012, 03:36 PM   #1370
Telstar is offline Telstar  Italy
What will the daughtercard contain?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1375 4th March 2017 07:58 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Copyright ©1999-2017 diyAudio
