XMOS-based Asynchronous USB to I2S interface
Old 22nd September 2012, 09:51 AM   #1201
zibra is offline zibra
I understand but have you tried REAL current measurements while playing hires files with NDK oscillators?
I assume Salas works better with more power headroom but if REAL current is about 350mA wouldnt it be better to just set it at 400-450mA than 600mA? Even for heat dissipation purposes? Have you tried how it sounds with different settings?
Old 22nd September 2012, 10:13 AM   #1202
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by shoom View Post
Hi Zibra
Yes Merlin thatís my take also.
I have my Salas BJT set up for a CCS of 670MA which seems to work well. From what Iíve read the Salas likes plenty on the CCS so just use a nice big heat sink.
I have my board and heat sink as follows
Franz Gysi style Salas
http://www.diyaudio.com/forums/power-supplies/192625-sslv1-1-builds-fairytales-10.html
Runs just warm and sounds sublime.
I used a linear reg previously and swapping in the Salas made a noticeable difference to the SQ.
Iíve had my WAVEIO for just over a year now and Iím still loving it.
Iím using my board with TP LVDS sender and receiver and that works very well indeed. Looking forward to WAVEIOís Daughter.
Great work Lucien
For 5Vout I recommend you use Mosfet instead BJT in Salas BiB reg.
Old 22nd September 2012, 10:25 AM   #1203
I know that measuring current by multimeter could have some "errors" but whats general idea of setting Salas shunt regulator for powering WaveIO.
If it takes real current for lets say 350mA with NDK oscillators on hires files and Salas works better with more power headroom, why dont you set it at 1A with very good heatsink? Does that mean it will work even better??
Im just curious whats the purpose of having such big power headroom in that case.
Sorry for beginner questions but I would really like to set it at its best.
Jakub
Old 22nd September 2012, 10:38 AM   #1204
lindamar is offline lindamar  Spain
Location: Madrid - Capital of the Kingdom of Spain / European Union
Originally Posted by Lorien View Post
That was the point: to work If you have some spare time please let us know what type of player are you using and with what settings. Maybe soon I'll have one iPad to play with for a short while (not mine) and want to take full advantage while I am with it. Thank you!
Lucian,
I mainly user the player that comes with the Ipad, but also tested other apps like "Golden Ear" (which plays almost any file format) and Spotify. I guess that you can virtually listen to any app that outputs sound ....
Nevertheless donīt forget that if you want to connect an USB cable to the Ipad youīll need a "camera adapter" like this one:
Apple iPad Camera Connection Kit - Apple Store (U.S.)
Cheers
Pepe
Old 22nd September 2012, 11:07 AM   #1205
vanwykca is offline vanwykca  United Kingdom
Originally Posted by zibra View Post
Can anyone please measure current for WaveIO board with NDK oscillators?
In first posts Lorien wrote current for board with FOX oscillators which consume much more power right?
I measured current connecting WaveIO to 4.5V battery and it shows 250mA. My friend measured it with hi-res files and it was up max. to 320mA.
It could be helpful information for setting up Salas shunt to work with WaveIO for example.
Jakub
Hi Jakub,
I am using WaveIO(NDK) with Placid HD shunt. Playing 24/192 res file the device consumes 320 mA as measured with Fluke 287. I've got the Placid adjusted to have 100 mA shunt headroom meaning the total current through the Placid is 420 mA. I hope this helps.
Cornelius
Old 22nd September 2012, 11:13 AM   #1206
Thank you Cornelius! Its exactly the same current my friend measured with 24/192 files!
Have you tried different settings with Placid HD shunt and found 100mA headroom optimal for sound?
Old 22nd September 2012, 11:15 AM   #1207
tagheuer is offline tagheuer  Canada
Updated list:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
Old 22nd September 2012, 11:18 AM   #1208
hochopeper is offline hochopeper  Australia
Updated list:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20.hochopeper
Old 22nd September 2012, 01:28 PM   #1209
shoom is offline shoom  Europe
Hi Merlin
Yes I did consider using the mosfet Salas but I only had BJT to hand. Iíll use the BJT for 3.3V on another project later.
A (slight) compromise in performance
Err yup.
But
Still loads better than the linear that I was using before.
Iím going to build up a 5V mosfet Salas when time allows.
Just as an aside
My board has the FOX oscilators
Old 22nd September 2012, 01:44 PM   #1210
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
