Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th May 2011, 12:25 PM   #1
Default add spdif input to player
Any projects out there that ads a spdif input to a dvd multi format player or cd player.
Old 6th May 2011, 11:28 PM   #2
What's the point? Ususlly the better DAC's are found "outside" of the players. And they already have SPDIF inputs as a minimim.
Old 7th May 2011, 03:15 PM   #3
There are very competent dac's in players available.
Reduce the number of aparatus and cables, maybe save some money, keep myself busy
Old 7th May 2011, 05:36 PM   #4
You need a regular SPDIF receiver (WM8804, DIR9001, etc) to generate the MCLK, BCLK, LRCLK and of course DATA. Intercept the I2S inputs of the DAC and use a switch to comute between the internal signals and the ones generated by the SPDIF receiver.
Old 8th May 2011, 12:17 AM   #5
I was hoping for a small pcb already somewhere available commercial or diy.
Old 8th May 2011, 12:38 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Very unlikely to be available for a DVD player - these use video-derived master clocks (27MHz springs to mind) which won't be easily produced from an SPDIF receiver chip.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 8th May 2011, 01:06 AM   #7
What??? That makes no sense.
The external SPDIF signal it is what it is. The 44.1 or 48 or 96kHz sample rates are what they are. It doesn't matter what is the clock that is planted in the player - the existing dividers take care of that.
DIR9001 or CS8416 don't need any external xtals or clocks, they don't care how the signal was created.
Look into this:
http://www.twistedpearaudio.com/digital/cs8416mux.aspx
Old 8th May 2011, 01:11 AM   #8
abraxalito's Avatar
Likewise your response makes absolutely no sense to me
<edit> I realised I could make my writing a little less terse. For example I said 'video derived' which is a bit ambiguous, so I'll clarify that by saying its better as 'video standards derived'.
Old 8th May 2011, 01:25 AM   #9
So if the main clock is derived from a 27MHz you cannot use a SPDIF receiver?
You imply that somehow that 27MHz changes the samplerate of the signals that arrive to the DAC? Really, what has to do the 27MHz video clock with the problem posted? A chip like SM8707 generates all the clocks in a regular DVD player.
Anyway what I am suggesting does NOT require any connection to the original clock. The i2s derived from the SPDIF receiver needs to be completelly switched (all the signals) at the DAC input.
Old 8th May 2011, 01:38 AM   #10
abraxalito's Avatar
Nope, that's not what I said. Just said its not so easy.
Please explain how you arrived at that in your thinking and I'll explain your faux pas.
A chip like ...
The DVD players I have have no separate chip to do that - its all integrated. On the outside there's just the 27MHz XTAL - to make the DACs play out correctly an SPDIF locked 27MHz would have to be fed in in place of the XTAL. On my super-cheap players there's no way to get data in to the DACs as they're on the single chip solution too. I do have a Pioneer DVD player with separate BB DAC chips though.
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 02:17 AM
mod NAD C520 (I'll add spdif input) hehe31 Digital Source 2 2nd April 2008 01:54 PM
How to add digital out to old CD player? bachiano Digital Source 4 15th November 2005 02:35 PM
Add SPDIF on SAA7310/TDA1543 Combination Tubeee Digital Source 7 20th July 2004 03:57 PM
Can you add a SPDIF input to a CD player? Leo V Digital Source 0 3rd October 2002 05:01 PM
Page generated in 0.11802 seconds (81.67% PHP - 18.33% MySQL) with 11 queries
