Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th April 2011, 04:59 PM   #1
Send a message via MSN to audio_tony
Default Remote control based around Atmel ATtiny2313
I have just taken delivery of a remote control kit based around the Atmel AT2313 and a ULN2803 transistor array.
I had anticipated building this into my preamp project, and using it primarily to control the volume - however I have run into difficulty...
I thought I would be able to drive the volume motor directly, but it seems that's not possible without some additional circuitry.
The kit has 2 'analogue' outputs which are essentially PWM outputs at around 8khz.
So, my rather ignorant question is..
How can I drive a motor (bidirectional for up and down control) from this PWM output?
I checked the output on my scope, and the mark space ratio varies when operating the "Volume" button on the remote.
I have Googled for a solution, but all the results I have seen so far, are purely PWM motor drive solutions, controlling only speed.
The ULN2803 can sink up to 800ma so drive current is not an issue for any proposed circuit.
Sadly, my knowledge of digital circuits is weak - I'm purely an analogue man at heart - so any assistance greatly appreciated.
TIA
Searchable DAC list (now in a database). * Easy searching of DAC chips / transport etc. *
Old 29th April 2011, 06:26 PM   #2
So, a bit more research reveals that I need some kind of integrator, which can then produce a (H)igh or a (L)ow to drive an 'H' bridge which in turn drives the motor.
Perhaps I asked the question above without doing enough research
Old 29th April 2011, 06:42 PM   #3
Mooly's Avatar
Its one of those things you need in front of you to play around with.
Is the output from the uP at a constant logic level when the keys are not pressed ? and does only one pin at a time generate this PWM signal. If so that should be easy enougy to detect and generate a logic 1/0 from to drive an H bridge.
A simulation free zone. Design it, build it, test it.
Old 29th April 2011, 09:09 PM   #4
Default Help!
So it looks like I have an even bigger issue.
Turning the volume up and down changes the mark space ratio - so that's ok.
However....
If I use an integrator I will get a DC output, but only in one direction by the look of it.
The output direct from the Atmel also drives an LED indicator - so this is analogue. But the voltage is always there - i.e. it varies up and down, but doesn't drop to zero when the remote button is released.
So if I tried to drive it from that, the motor would just continue running, in whichever direction was previously selected.
Am I overlooking something here?
I can add some pics of the PWM scope waveforms if it helps?
Thanks.
Old 29th April 2011, 11:00 PM   #5
Banned
What is the drive voltage for the volume control?
You would normally use 2 binary outputs from the controller to drive the motor, presuming a single speed of operation is satisfactory.
One output would drive the H-bridge for travel in one direction, the other, obviously the other direction. The H-bridge is simply a way to wire the motor so that independent drive can be applied to it in either direction. PWM would not be required,
w
I'll draw you a diagram if you need it. You don't need to use FETs, you can drive relays off the ULN2803.
Old 29th April 2011, 11:20 PM   #6
Banned
As long as you can't drive 2 outputs simultaneously, this should be OK.
w
If you still want to make use of the PWM output, you can feed it into the relays to drive the motor, @8k the motor will accept it as readily as DC.
Old 30th April 2011, 06:25 AM   #7
Mooly's Avatar
Transistor version here... this is part of a circuit I actually designed and built to add RC to my amp. As myself and Waki say, you normally need to outputs EITHER of which go high when volume up/down is pressed but NEVER together. The pot on the base of the TIP111 allows the motor speed to be set, something thats important to get the feel and usability correct of how fast the motor operates. Points 6 and 7 are the "logic" inputs to the bridge.
Old 30th April 2011, 08:31 AM   #8
Thanks guys.
I have concluded that I have one of two options.
I can either:
a) Reprogram the micro (that would be a steep learning curve!!)
b) Use the "Volume" (up) on the remote to turn it up, and the "Prog" (down) on the remote to turn it down.
This because it would appear that I only have a single output (for each remote function), which appears to be intended to control motor speed rather than direction.
Even the numbers on the remote are on/off toggles, meaning that you press a number, and an output is driven high, then press the number again and it goes low.
One other oddity I have noticed is the PWM output of the Volume and Prog controls.
If I have the motor connected to the output of the ULN2803... I press Volume UP, and the LED indicates a gradually rising drive voltage, but the motor doesn't move - then just around the point that the LED reaches maximum intensity, the motor begins to turn.
The motor I'm using is 5V, as is the drive from the ULN chip.
This is odd, because I would have expected a continuous analogue drive from the ULN, not so? (given that the input appears to be a continuously variable analogue drive)
Old 30th April 2011, 11:39 AM   #9
Mooly's Avatar
This is absolutely brilliant and works exactly as described... just in case you go down another route with all this
FPRC5RX - DIY learning IR decoder
A PICKIT2 can programme the micro.
This was the module I used in my amp before I started playing around with the PICKIT,
http://www.antratek.ie/pdf/1_933.pdf
I have a feeling its not available now
Old 30th April 2011, 12:05 PM   #10
I just checked on the website, and was still able to add the item to a basket, so I presume it's still available.
Ironically, they're in Leeds (which is where I am...).
Thanks for this, although I may just embark on a crash course to learn about AVR programming!!
Motorized ALPS-based remote control kit with ext. on/off, sleep and mute functions! Altmustech Swap Meet 5 26th June 2010 02:06 PM
how to remote control a rotary switch based attenuator Giordano Parts 40 29th October 2008 08:01 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
Page generated in 0.11188 seconds (81.59% PHP - 18.41% MySQL) with 11 queries
