| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
i purchased the DCX used. individual said there were no problems with it and i may be stuck with it. input A doesn't work and has the egg frying sound. input B works about half with noises also. looking to have it repaired it possible. i've sent a request to Behringer. just waiting on a response. didn't know if anyone else has had one repaired.
#2 |
try to plug and displug the rubber cables from their connectors, clean them with a spray, sometimes it's enough.
good luck |
#3 |
Yep, I agree. I use cotton wool buds which have been made wet with WD40, and applied to the connector pins on the ribbon cable socket. Although it works its a temporary thing, after a few months I've found you've got to do it again.
#4 | |
Instead use clean clear solvent like CRC CO Cleaner only. Do the connectors one at a time......you may have to remove hot melt glue locking the connectors down. Polish the pins with a cotton bud wetted with the spray, rinse with a quick spray, fit connectors and wet with spray whilst working connector up and down the pins. Remove connector and rinse pins and connector with another quick spray. Allow solvent to evaporate and then refit connector. Once this is done power it up and see what you get. Behringers are fine gear but let down by lousy connectors....this problem is not uncommon. Eric.
I believe not to believe in any fixed belief system. |
#5 |
i have some DeoxIT cleaner at home that worked well on my Mackie board. i'll insulate the bottom of the case and clean the ribbon connections. if that don't work, i'll try to sell the unit and re-cope some of my money. don't know if anyone would buy a broken unit. also, does behringer have a replacement parts for these?
#6 |
#7 |
Frying egg sound is likely bad ribbon connectors. They come loose. I think they do that because of thermal cycling from turning power on and off. Haven't had the problem since I stopped turning mine off.
#8 |
Deoxit must be removed after use.....use CO Cleaner.
Eric.
#9 |
| MiniDSP vs DCX2496 vs DCX2496-Modded vs DEQX | gainphile | miniDSP | 20 | 14th September 2011 09:24 AM |
| Can this be repaired? | DJMAC | Multi-Way | 4 | 14th December 2008 03:00 PM |
| Can a mylar rip be repaired? | jeffshort2000 | Planars & Exotics | 6 | 8th December 2007 01:30 PM |
| Almost repaired...but not yet...help a poor father | bramdo | Digital Source | 4 | 30th January 2007 09:43 PM |
| Can this be repaired?? | ericpeters | Analogue Source | 15 | 22nd January 2005 10:32 PM |
| Page generated in 0.09992 seconds (87.19% PHP - 12.81% MySQL) with 10 queries |
