Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st April 2011, 01:16 PM   #1
chrispenycate's Avatar
Default SPIDIF–AES/EBU interfacing.
I basically live in a recording studio, and the console has basically AES/EBU digital inputs, and just a few (24) analogue, and one ADAT (8 tracks)
I've noticed that several of the keyboards I work with have SPDIF outputs (and sometimes inputs, too, but that's another problem; the AES/EBU receiver chips have clock converters on them, in the other direction it's word clock distribution). Now, I've checked, and the desk inputs will work with just an adaptor cable, at least for short distances, or a 75Ω- 110Ω transformer (that's an omega, for ohms, in case the site software turns it into a ?) but I'm an old style engineer who believes in balancing and levels for long runs.
If it were analogue, where once I would have put a balancing transformer, now I'd put an op amp circuit; I was wondering if a CMOS inverter chip would boost the level and give my antiphase drive, just needing a couple of resistors to match recommended levels and impedances. A little box, close to the keyboard rack, boosting the signal for the run to the machine room…
Has anyone tried anything like this?
Old 21st April 2011, 01:46 PM   #2
DorinD is offline DorinD  Romania
DorinD's Avatar
Maybe this could help: Interfacing AES3 & S/PDIF
ASRock AtomIon 330 -->V-Link-->SRC/DEQ/DCX2496-->3-way horn + multi-subs
Old 22nd April 2011, 07:43 AM   #3
Zoran is offline Zoran  Serbia
It is maybe better to use one diferential driver, then galvanic isolation chip (ADuM series)
and after that another dif to dif driver chip
or with just 2 chips first galvanic isolation + dif. driver + 2 x good power supplys + box
and You can have multiply output.
for the impedance matching use Pi or T networks not only resistors...
cheers
Dual Wire AES/EBU Output to Single Wire AES/EBU Input EUT Digital Line Level 2 7th January 2011 07:00 AM
CDMPro2 aes/ebu? jev Digital Source 4 22nd October 2009 07:03 AM
In - Out AES/EBU santosa Digital Source 1 26th July 2005 04:28 PM
SPDIF to AES/EBU Kari Digital Source 4 21st February 2004 11:29 PM
Page generated in 0.07643 seconds (68.93% PHP - 31.07% MySQL) with 10 queries
