Musical Fidelity Digilog Dac
Old 29th April 2011, 12:57 AM   #11
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yeah, I've worked up my own rationales too, just wanting to test them. One you haven't mentioned is the extra noise caused by having a sweating (900mW) digital chip right next to the DAC. So I wanna try a lower power filter. I can't follow your point about doing oversampling in software rather than hardware - you're assuming there's already a CPU in the system?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 30th April 2011, 08:54 PM   #12
Lenin21 is offline Lenin21  Singapore
Wakibaki,
I'm with you on the 'upsampling embedded errors is nonsense' argument, but I believe that one of the UK magazines (Hi-Fi News, I think) investigated the issue of word length and sampling rate (from both technical and subjective standpoints, with pleny of measurement to back up their findings). If memory serves, this would have been around the mid to late nineties.
I think the oversall conclusion was that word length has surprisingly little effect on data quality/integrity (from both technical and subjective standpoints) while sampling frequency was found to demonstrate clearly measureable effects, on both fronts.
My memory really is getting worse as I get older (I've started for forget why I walked into a room...) but I'm faily sure about that feature article.
I'm still recovering from a recent visit to the hell that is my loft, but when I recover, I'll launch another expidition and see if I have a copy to scan and post.
Old 21st July 2011, 02:26 AM   #13
Johnnz is offline Johnnz  New Zealand
I too have one of these fantastic dacs which also has that odd repair job/ extra components added in.
I am wondering if anyone else has any issues with their Digilog making a popping noise through the speakers when turning it off (if done before turning off the amp)?
Can anything be done about it? I am just worried that it could damage the amp or speakers.
Old 22nd July 2011, 04:54 AM   #14
ekidnah09 is offline ekidnah09  Australia
Johnnz,
I am currently upgrading mine at the moment so cann't check. Just turn the amp off first for a while till I get mine back togeather. (this is recommended by a lot of people anyway)
Yes it can damage your speakers and possibly the amp.
Old 17th August 2011, 02:23 AM   #15
Johnnz,
I turned the dac of first with the cd player on so the dac was locked and no poping noise.
I'm still having toslink input dropping out problems so will be pulling it apart again and when I do that will try and trace out the mute ccty which should stop the poping noise on turn off.
I hope this helps.
Old 27th September 2011, 01:22 AM   #16
Default Digilog Mute Circuit
Johnnz,
If you measure the voltage across r48 it should be 0v when the DAC is on but not locked and 3.25v when it locks to the incoming signal.
If you are not getting that then there is a problem.
Let me know how you go and I will try and help but I am only a learner.
Old 5th November 2012, 08:17 AM   #17
Tyimo is offline Tyimo  Hungary
Hi!
What is the output impedance of the Digilog?
Greets.
Tyimo
Old 16th March 2013, 02:53 PM   #18
Smiffy is offline Smiffy
I found it.Just gotta shove it in a link somewhere.
Musical Fidelity Digilog DacHide this!Advertise here!
Musical Fidelity Tri-Vista 21 DAC andy2 Swap Meet 1 4th January 2011 05:41 AM
HDMI input for Musical Fidelity DAC ronenash Digital Source 0 24th March 2008 08:12 AM
Musical Fidelity The Preamp mosfet1 Solid State 0 12th December 2006 11:22 AM
Musical Fidelity- Do you know it well? SugarMedia Solid State 2 26th February 2005 01:11 AM
Musical Fidelity ANTHONY2181 Swap Meet 0 28th September 2002 05:10 PM
