| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hello,
I was wondering of someone could help me do this if possible. Please refer to this kit: DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 | eBay I have a pair of Edcor 10k:10k transformers that were pulled from another DAC project. I was wondering if these could be used with this kit to replace/bypass the NE5532 opamp on the board. If possible could someone tell me exactly what I would need to do/where to make the connections? It may not be an upgrade in the end but I am learning and like to experiment. Thanks for your help, Jeff |
#2 |
Hi Jeff
If you look at the AK4393 datasheet here: http://www.asahi-kasei.co.jp/akm/en/...k4393_f02e.pdf Pins 20 - 23 are the outputs. I presume, looking at the ebay listing, that the group of 4 resistors between the DAC chip and op-amp are on the DAC output pins. Connect the Edcor's primaries to these. You should probably measure the value of the resistors first and see if they need to be changed to get the correct loading.
Rich |
| Scythe Kama Bay SD-1100 input section opamp replacement or bypassing? | rickedd46 | Class D | 0 | 26th June 2010 11:49 PM |
| Is there a bridgeclone kit or PCB with integrated opamp crossover? | swak | Chip Amps | 0 | 16th August 2007 01:38 AM |
| FS: Amp6 kit, caps, transformers | Dennis Hui | Swap Meet | 5 | 3rd August 2007 04:47 PM |
| WTB: Power Transformers For BrainGT Mono Block Kit | jawbreak | Swap Meet | 1 | 2nd January 2005 06:26 PM |
| What value of cap for opamp PS bypassing? | overmind | Solid State | 4 | 13th February 2002 06:47 PM |
| Page generated in 0.06556 seconds (71.16% PHP - 28.84% MySQL) with 10 queries |
