| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
A part of the "amplified DC security issue", can I DC couple a PCM1710 DAC directly to the low pass opamps filter?
Can I get rid of all DC coupling capacitors in the CD player (after the DAC) if I know that my amplifier has an DC input CAP? Are we lowering the distortion in this way? Thanks |
#2 |
A low pass filter does not remove DC, but a high pass filter would.
You can remove DC coupling capacitors in between your CD player and amplifier, but any circuits in the middle will need to be examined to determine whether the bipolar power supply rails have enough voltage range to support any DC offset that might occur. |
#3 |
If there is an input selector and a volume control between the CD player and the power amplifier, it is better to not letting DC on them - they will create noise.
#4 |
Sometimes a square peg fits a round hole just fine
and make certain low leakage caps are used or dc will build up on the input to the opamps until it overrides the rails. yes dc on any pot is bad!! in your description without any output caps, if dc build up in the dac and you connect it to the amp, a dc transient will be unleashed that will probably pass the cap via leakage
| DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM | stevep314 | Analog Line Level | 0 | 10th August 2010 09:15 PM |
| Class D output low pass filter EMI suppressor | rickco | Class D | 4 | 28th October 2009 05:15 PM |
| Low pass filter on DAC output | Tenson | Parts | 1 | 12th September 2006 02:10 PM |
| Blocking capacitor as a high pass filter? | NV&H | Solid State | 4 | 15th February 2005 06:20 PM |
| Page generated in 0.07917 seconds (71.32% PHP - 28.68% MySQL) with 10 queries |
