| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all,
Back to the Lampucera DAC again (old style). I have just used the DAC for the first time and it all works fine in standard trim. I am using a 9-0-9 VAC transformer, but it would seem that a 12 VAC transformer is recommended. Is there a problem using a 9V transformer, as the rectified voltage will be 12V anyway? I am using the supplied power supply board that came with the DAC kit, but I was wondering if using a 12V transformer would give the voltage regulators too much to do. The DAC DC supplies appear to be 5v and 12V. Any ideas? Many thanks |
#2 |
9V * 1.414 (after rectification) = 12.726V Don't know type of diode used for rectification so not gonna add diode voltage drop, but still 0.726V of overhead is less than drop-out voltage of the regulator, so you get no regulation.
12VAC transformer for 12VDC regulated out sounds right. |
#3 |
No, true, but there is a 5V supply on the board also.
#4 | |
No problems so far.
#5 |
Would that be a 12-0-12V transformer? Would it be possible to perhaps use a 2x 0-12V transformer somehow?
| new gigaworks lampucera board | pforeman | Digital Line Level | 0 | 2nd February 2011 07:32 PM |
| Lampucera-Inspired CS4397 Complete DACs! | gripracer | Swap Meet | 2 | 7th October 2010 08:48 AM |
| Op-amped lampucera problem | defec | Digital Source | 1 | 14th September 2010 03:22 AM |
| Need help with DAC project - almost Lampucera | oracle | Digital Line Level | 0 | 6th July 2010 10:57 PM |
| Newbie query - Lampucera DAC tweak | hillbear | Digital Line Level | 5 | 3rd July 2010 07:49 PM |
| Page generated in 0.08771 seconds (72.32% PHP - 27.68% MySQL) with 10 queries |
