DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 98 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th December 2011, 11:44 AM   #971
F1 FAN is offline F1 FAN  Canada
A true 75ohm coax preferably with BNC conectors is ideal.
Old 15th December 2011, 02:51 PM   #972
I agree on the 75Ohm and BNC connector. There have been several discussions, and some bun fights, on this and other forums pointing out that for a SPDIF coax to be 'true' 75 ohm it must have a BNC connector at both ends. Some members with extensive design experience in RF and SPDIF interfaces insist that an RCA connector can never be 75 Ohm, no matter what the marketeers try to tell us.
There are a couple of excellent threads here and at another forum which have schematics and discussions for properly terminated active SPDIF input and output stages. I have built and installed in my RCD965BX the active output stage shown in the link below. This made an immediate improvement in clarity and definition.
SPDIF output stage: Digital transformer. The schema appears first on post #67 with discussion in the following posts.
I have just finished but not yet installed the active input stage shown in this link to another forum. I will soon be installing this input stage in the DAC under discussion in this thread.
DIYHiFi.org • View topic - Anyone interested in..............
For the schematic, go to page 2 and scroll down to the Jocko Homo post subject "Do I have to do everything around here.........…" . It's not quite as easy to use as this forum but worth the effort. The active stage is designed for the CS841X series of receivers. The discussion in the posts following is very useful.
Jocko also says that a long SPDIF cable is better, especially if you have a TDR to measure and correct the reflections. When I get the active stage installed and checked, I intend to try a 6.0m length of Canare cable. I don't have a TDR (who does?) but somewhere in that thread mention is made that 6.0m is a good starting point.
Old 15th December 2011, 05:45 PM   #973
skouliki's Avatar
Originally Posted by ekidnah09 View Post
skouliki
The Pioneer PD-D6 sacd player turns the digital outputs off when in pure direct mode, have you checked that this feature is off?
Well i feel like a moron, should have checked this feature. With direct mode off, the dac works flawlessly Thanks for the suggestion ekidnah
Old 16th December 2011, 01:21 PM   #974
What the most important reg that should be changed to a better reg like SALAS Shunt in the DAC?
CS8416:
VA- Analog power supply. +3.3
VD- Digital Power-Digital core power supply +3.3V
VL- Logic Power-Input/Output power supply +3.3V
AK4396:
DVDD- Digital Power supply +5.0 V
AVDD- Analog power supply +5.0 V
OPAMP:
+15.0 V AND -15.0 V
Old 16th December 2011, 01:29 PM   #975
Reality first!
ClaveFremen's Avatar
The one for the opamp, change the others with OnSemi MC78xx
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 16th December 2011, 06:23 PM   #976
CS8416:
AK4396:
OPAMP:
+15.0 V AND -15.0 V
AK4396:
I check the Gold reference regulator and the SALAS reg shunt ....
Much better with the SALAS reg shunt
OPAMP:
+15.0 V AND -15.0 V
Of course SALAS reg shunt
But it's my opinion
Serge
Old 16th December 2011, 07:24 PM   #977
Reality first!
Originally Posted by Sergelisses View Post
AK4396:
Hi Serge,
I do agree, after the opamp regulator the AVDD is the next one that would benefit more from a better PS.
Dario
Old 19th December 2011, 10:37 AM   #978
50AE is offline 50AE  Bulgaria
Send a message via Skype™ to 50AE
I'm looking to replace the opamp with a tube output.
May someone recommend me a lampizator circuit, suitable for the AK4393 DAC?
Thanks!
Old 19th December 2011, 07:46 PM   #979
Default Valve Output
Have a look at the Tubecad website for a BCF.
Broskie Cathode follower.
This circuit converts a balanced signal to an unbalanced signal.
As it is a cathode follower the is no gain, although the DAC is voltage out, you may not need any gain.
If gain is needed look at the unbalancer.
It seems a waste to me to only use one side of the signal and ignore the full voltage swing.
Both of these circuits provide excellent drive ( low source impedence).
I have tried the SRPP circuits as per Lampizator and did not prefer the sound.
You may like it
Old 20th December 2011, 09:13 AM   #980
buzzforb's Avatar
I will be ordering one of these today, and was wondering if there is a link to the post with suggested mods?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
