DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 91 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th November 2011, 08:39 AM   #901
Oh, I think you misunderstod nr.
I have upgrsded anordning to tour BOM
Old 30th November 2011, 09:25 AM   #902
Reality first!
ClaveFremen's Avatar
OK, you're right, I've read 'without' where you wrote 'with'...
I don't know how the squeezebox sounds but it seems strange to me that his analog stage is on par with the modded MINI2496...
The analog stage of my SACD player sounds only a bit better but it's a 15Kg player that in 2003 costed around 2000€...
Exactly what you bought as per my BOM, other forumers said so and in reality they picked up only a part of it...
Can you post a photo or two?
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 30th November 2011, 09:27 AM   #903
LOL - fuc.... phone
I mean:
Oh, I think you misunderstood me.
I have upgraded according to your BOM
/Bjarne
Old 30th November 2011, 09:32 AM   #904
Here they are
Old 30th November 2011, 09:43 AM   #905
Reality first!
Here they are
Thanks Bjarne
Seems all as per my BOM...
The only two difference are the Nichicon FW instead of BC038 and supplied film caps instead of ceramics... they should sound good too...
Did you tried others SPDIF coaxial cables apart the Canare?
This DAC is very sensitive to the quality of the cable.
For instance I've used two BlueJeansCables: one with Belden 1505F and the other with Belden 1694A.
The difference was HUGE.
Dario
Old 30th November 2011, 10:25 AM   #906
Tenson is offline Tenson  United Kingdom
The reason you can't hear any difference is because the distortions of both kit are below audibility. Well done, your ears work!
For a bit of interest, have a go at this comparison: http://www.audiosmile.com/forum/showthread.php?t=29253
Old 30th November 2011, 11:14 AM   #907
erin is offline erin  Australia
I am deeply disappointed
I have listened and listened, my wife have been listening, my son with young ears have listened. We can not tell the difference between SBT analog output vs. this DAC.
Either there is a plug in my stereo or else this DAC is a "fart in a horn lantern".
I like your good humor
Are you using soundcheck mods on your SBT?
How long did you leave the DAC running?
What do you use to connect the analog output from the PCB to the RCA cables?
The SBT also uses an AKM DAC, but not as good as this one.
You are right that something else is bottlenecking your stereo. This DAC will sound better than SBT output. We just have to find out what the problem is.
Old 30th November 2011, 12:31 PM   #908
Bjarne which opamp are you using?
Old 30th November 2011, 01:03 PM   #909
50AE is offline 50AE  Bulgaria
Send a message via Skype™ to 50AE
I will say it loud and clear:
My AK4393 DAC gathering dust all these months - I just tried it using a 12-0-12 tranny and the default components - no fancy stuff like cerafines, ultra fast diodes and additional decoupling.
This little DAC definitely BLOWS AWAY my modded X-fi music sound card! Even from the first run, no burn in! Bass is no present, but it will be after new caps an burn in . What about using a capacitance multiplier on it?
I can't wait to mod this little guy!! It sounds so cool!
May anyone recomment me a suitable valve output stage shematic in idea to replace the opamp in the future?
Old 30th November 2011, 01:30 PM   #910
namcir is offline namcir  Philippines
namcir's Avatar
Bjarnevip
maybe what you here from your system right now is veiled. its like you dont see much of the picture because you are watching it on an old monitor while your audio sources are very good some of your components are hindering it..you can try to eliminate the opamp preamp...
try to read this...
How good is the Ion Obelisk 3X / X-Pack Pre-Power amp combination | AVForums.com - UK Online
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
