DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 26th November 2011, 04:18 AM   #891
bmwman91 is offline bmwman91  United States
Send a message via AIM to bmwman91
Excellent thread!
I am probably going to use THIS DAC (suggested above) in a project I am brainstorming for. Basically, I have a wireless audio receiver that uses a WM8728 DAC (in software control mode). Well, I would like to improve the DAC subsystem and then feed a LM3886 kit from it.
So, can anyone foresee any issues if I was to grab the I2S lines that originally went to the WM8728 and fed them to this DAC (bypassing the CS8416 chip)? I assume that I would need to put some thought into controlling the MUTE line to avoid silly pops and other noises. Input would be appreciated.
If someone came up with a I2S-input version of this board, that would be really neat! Until then, I am happy to try to hack something together.
Old 26th November 2011, 01:04 PM   #892
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
This board uses resistors in the i2s lines, so you can just remove the resistors and hook up your i2s straight into the resistor vias.
Issues would be that i2s needs very short wires or sound will not be optimal.
If your wireless audio reciever does not have spdif output I'd suggest getting a Logitech Squeezebox touch and using the spdif output on the touch. With the soundcheck mods its an excellent transport.
Old 27th November 2011, 07:31 AM   #893
Yeah, passing a 12MHz clock over long wires sounds like a risky affair. I will have to play around with it. I may be able to work out something using header pins or something to do a board-board connection.
I will be sticking with this particular hardware because it is effectively a wireless soundcard. Whatever audio is being played on my laptop gets sent over wireless and reconstructed in the receiver. I looked at the Squeezebox initially, but a music server wasn't want I was after. Having the ability to broadcast the audio from my laptop enables all sorts of movie and music options, which didn't seem possible with the SB since it actually decodes/plays the media as a sort of master/slave device, when I really just want a slave device.
Old 27th November 2011, 09:00 AM   #894
qusp is offline qusp  Australia
qusp's Avatar
clock over headers is ugly as hell, better to just use short lengths of either 50ohms mini coax, or cat5 soldered directly. TPA is releasing a board called the teleporter that might be of interest; it uses LVDS, which is a balanced networking protocol that enables clock and i2s lines to be transmitted rather well over 100M. in this case you would use cat5 or cat6 with a transmitter and reciever
Old 27th November 2011, 06:33 PM   #895
That seems a tad overkill! I am only grabbing the clock/data lines & running them to a board about 1" away. I will play around with it & see what happens. Unfortunately, I cannot see what is generating the clock signal since it is wrapped up under a soldered-down EMI shield in the product. If it is a crystal, then yes, I must be careful since they are super sensitive to parasitic effects. If it is a microcontroller GPIO pin, then that makes things easier. Anyway, I don't mean to hijack this thread so I'll drop the discussion of this in here.
It sounds like this DAC board is very easy to use with an I2S input, provided that the source tolerates some hacking!
Old 30th November 2011, 06:10 AM   #896
Bjarnevip is offline Bjarnevip  Denmark
Unhappy I am sad
I am deeply disappointed
I have listened and listened, my wife have been listening, my son with young ears have listened. We can not tell the difference between SBT analog output vs. this DAC.
Either there is a plug in my stereo or else this DAC is a "fart in a horn lantern".
My setup:
Homebuild PreAmp with opamps
Ion Systems Obelisk 3X with XPAK
SBT with linear PS
HDD connected with linear PS
AK4396 DAC
Kimper signal and speaker cables
Canare LV77 digital cable
Speaker Royd Sapphire
When I got my preamp, I experienced a significant improvement in sound. That is, it was very audible.
The same I experienced with Kimper cables.
/ Bjarne
Old 30th November 2011, 07:49 AM   #897
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Hi Bjarne,
you're using the vanilla AK4396 DAC?
With the R-Core transformer?
BTW, what is SBT?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 30th November 2011, 07:55 AM   #898
Vanilla? If you meen with your modifications(BOM) Yes.
And R-core - YES
SBT = Squeezebox touch
Old 30th November 2011, 08:15 AM   #899
Reality first!
And R-core - YES
Yes, I meant stock, as it is sold.
The stock dac is nothing special at all, at least some mods are mandatory.
Start upgrading the LPF and regulators according to my BOM (ca 5 with standard resistors).
If you like results than you can upgrade the rest.
I bet you'll do it....
Dario
Old 30th November 2011, 08:30 AM   #900
Oh, I think you misunderstod nr.
I have upgrsded anordning to tour BOM
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
