DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 6th November 2011, 10:30 PM   #861
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by apoopoo999 View Post
I just looked at your bom again and I see you noted RFS are better then the KZ I am using right now. Should I use RFS (Silmic) or ROA (Cerafine)?
It's also a matter of taste but for this DAC I recommend Cerafines or, even better if you can find them, Blackgate FKs/PKs (not standard ones, Cerafines are better here)
You should also bypass the OPA827 rail to rail with a 10nF Wima FKP2.
Yes you are correct, those are some texas instrument regulators I had. Right now I am still building the Salas shunt 12v regs. When those are complete I will report back.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 8th November 2011, 01:27 AM   #862
apoopoo999 is offline apoopoo999  United States
Hey Dario you were right, the cerafines sound much better then the kz for opamp decoupling. Now the ak4395 is more open and there is much more detail in the mids.
I also added the 12v salas shunts and bypassed the opa827
Uploaded with ImageShack.us
Old 8th November 2011, 01:37 AM   #863
Reality first!
Impressive work
Dario
Old 8th November 2011, 03:49 AM   #864
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
KZ is good for whitegoods control boards. Not good for audio. IMO.
Old 8th November 2011, 06:17 AM   #865
Bjarnevip is offline Bjarnevip  Denmark
Whitegoods boards????
Old 8th November 2011, 06:19 AM   #866
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
Washing machines, dish washers, microwave ovens etc
Greg Erskine
Old 8th November 2011, 06:20 AM   #867
Thanks;-)
Old 8th November 2011, 07:46 AM   #868
Sergelisses is offline Sergelisses  France
After the OPA 827 ,i tried the OPA1641 .....
Also very good ...better ..perhaps
The OPA 827,OPA1641 JFET input seem better than the bipolar AOP .
If you have some informations about the difference between the technologies
i am interested .
I also used a SALAS shunt Reg for the AOP 2x15v ,what is the value of the bypass capas ?
Serge
Old 8th November 2011, 12:17 PM   #869
carlmart is offline carlmart  Brazil
Serge,
Even if some opA1641 specs are worst than the 827, like GBP and slew-rate, price is more affordable.
And it gets better. There's a dual version for that chip, called opa1642, which should simplify assembly. Pity DIP8 are non-existent anymore.
Old 8th November 2011, 01:11 PM   #870
Serge
bypass for the opa827 is 10nF (.01uf) Wima FKP2
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
