DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st May 2011, 02:00 PM   #61
erin is offline erin  Australia
Originally Posted by detoxer View Post
This little dac is an unbelievable performer excellent detail,smoothness,bass slam ect....
Its way better than the Cirrus Logic Dac chips isn't it?
Glad you like it.
Old 1st May 2011, 03:13 PM   #62
It definitely is, I was using a lampucera board prior to this discovery. I have purchased several of these boards to experiment with, I like very much where the Dac is right now. I will be assembling another very soon with extra care taken to soldering and component placement.
Old 2nd May 2011, 01:40 AM   #63
Did you compare the sound of AK4393 vs AK4395?
What are your thoughts on the matter?
Old 2nd May 2011, 03:12 AM   #64
sendler is offline sendler  United States
Default CS43122 better
Glad you like it.
As much as I like the DEQ2496 with an AK4395 running direct dropped in for it's EQ processing, digital level control and meters, I have to admit that the sonics of the CS43122/ 4397 are very slightly better in absolute terms. The AK4393 has found it's way into a lot of different products because of it's low price, such as my Firewire 410 that I use for PC active cross, so this keeps my interest in the 4395 high as it can be dropped in to many different sound cards to bring them up to state of the art. I was dissapointed with the PCM1798 and felt it was a step down in top end detail to the CS or AKM dacs and did not live up to the hype or it's high price although dacs that follow it with an expensive tube I/V stage seem to get rave reviews.
Scott
Old 2nd May 2011, 08:48 AM   #65
awpagan is offline awpagan  Australia
"As much as I like the DEQ2496 with an AK4395 running direct dropped in for it's EQ processing, digital level control and meters, I have to admit that the sonics of the CS43122/ 4397 are very slightly better in absolute terms. The AK4393 has found it's way into a lot of different products because of it's low price, such as my Firewire 410 that I use for PC active cross, so this keeps my interest in the 4395 high as it can be dropped in to many different sound cards to bring them up to state of the art."
Scott
Was the CS43122/ 4397 implemented the same way with EQ processing, digital level control etc ?
The AK4393/5/6 are all interchangable
The AK4395 has a better filter
Allan
Indecision makes the world gone round.
Maybe
Old 2nd May 2011, 08:52 AM   #66
namcir is offline namcir  Philippines
namcir's Avatar
please evangelion i would like to see wm8805 and ak4396 paired with a revised power supply circuit planning to buy one
Old 2nd May 2011, 09:01 AM   #67
namcir's Avatar
would it be better if we have some option with this dac kit in the power regulator section for ak4395, ak4396,....also in the digital input reciever (can change wm8805 or cs8414 or cs8416) etc...
Old 2nd May 2011, 09:26 AM   #68
Lets not forget that the beauty of this kit is that it is very simple and has short signal paths and that it plays like a killer and only costs about $37 delivered. Adding complexity and components increases the parts count and board size and cost.
Old 2nd May 2011, 09:29 AM   #69
namcir's Avatar
for a few dollars will be ok.... adding some flexibility and upgradeability what do you think?
Old 2nd May 2011, 09:58 AM   #70
Default Same
The CS43122 was run with the same EQ settings running digital out from the DEQ.
The AK4395 is a drop in replacement except for the need of 5v for the digital supply.
Scott
Allan
Scott
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
