DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 65 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th September 2011, 01:01 AM   #641
F1 FAN is offline F1 FAN  Canada
Originally Posted by nrg2009 View Post
F1 fan, is that formula 1 or nelson pass' F1 amplifier?
Formula 1,but I'm a fan of Pass as well having built a number of his projects over the years.
Old 11th September 2011, 02:41 AM   #642
nrg2009 is offline nrg2009  United States
Monza tomorrow, i walked on that track several years ago. Im debating if i `need' to build an Aleph 2 this winter, any advice?
Thanks, enjoy the race.
Old 11th September 2011, 02:47 AM   #643
erin is offline erin  Australia
Originally Posted by Nosian View Post
hi Erin and every one, I wonder if any of these stages this or this are suitable for this dac?
Both of those output stages are designed to be used with current output DAC chips like TDA1541. To use them you would have to remove the IV resistor on the boards. If you absolutely must use an SRPP output stage perhaps this cheaper one would be just as good?
My personal experience with sub miniature tubes is that they are very microphonic and are not worth the hassle. So I would avoid the 5744 output stage.
Old 11th September 2011, 04:59 AM   #644
Monza eh,the sheer speed would make it an awesome venue to see an F1 race in the flesh.I'm hoping for the red cars.
I have built the Zen and a number of preamps,but none of the Aleph's as of yet so can't offer any specific advice.Ofcourse the Pass area would have many a willing and experienced advisor.
Old 11th September 2011, 05:13 AM   #645
data is offline data  Australia
These can be used direct out with a wide range of DAC chips Universal Stereo Tube Output Stage | Diy HiFi Supply
They use it in there Satch DAC.
Old 12th September 2011, 08:19 AM   #646
thanks every one for the advice. I'm just thinking about the best output stage. op-amps are bad boys or good boys? LTs or OPAs or LMs?
But this dac is a voltage dac, no amplification is necessary. It needs filter and buffer, doesn't it? would some some of the grate guys though some light on the stage? Tube, trannys, JFT, op-amps? what's the best solution?
Old 12th September 2011, 08:26 AM   #647
Transformers work well, but as with everything the model/brand will dictate the sound, some are neutral some are warm, and some are not. Also quality plays a big part in the end result.
Tube stages are variable also in that the choice of tube and the implantation will dictate the end result too.
Personally I dislike Opamps, so for me transformers or a tube stage would be my picks.
Best will be different for everyone, personal preference plays a big part.
But that's just my view
Old 12th September 2011, 10:57 AM   #648
Reality first!
ClaveFremen's Avatar
OPA827 is such a good opamp with such a good PSRR that I will not bother....
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 12th September 2011, 05:03 PM   #649
thanks Erin so much for seeking this board. As I can see it has not balanced input and I just wonder what will happen with +/- (balanced?) output of AK4396?
Old 12th September 2011, 06:32 PM   #650
I use Opamps on cork board if I run out of thumb tacks, they work really good
Ok, I am joking
But if you haven't tried those alternatives, you will never know how well they work, no?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
