DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 18th August 2011, 10:42 PM   #531
sharpi31 is offline sharpi31  United Kingdom
Hi Nosian,
Sowter 9545 (and the recommended loading) should be used with current output dacs, not voltage output dacs like the AK4393/5/6. A very different beast altogether.....
I wouldn't even try using these transformers - you may even damage the dac if you use the primary loading you detail (way less than the 1Kohm minimum AC load).
Buy a current output dac kit and use the Sowters with that (I'm sure it would be great). For the AK4396, buy a couple of half decent 600ohm 1:1 transformers on ebay for $30.
Old 19th August 2011, 12:16 AM   #532
sterlingmck is offline sterlingmck  Australia
Default Voltage Regs
Clavefremen
On you BOM you spec a 12 v regulator replacing the 15 v regs.
Is there ary technical reason for doing so
I understand the the circuit will work with both voltages but the 12 v may run hotter as the voltage drop is higher
Old 19th August 2011, 12:57 AM   #533
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
No, just to use the same voltage rating of the original kit.
In fact the MC7815/7915 are even better performing (in my definitive DAC I'm using 15V ones).
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 19th August 2011, 07:06 AM   #534
Trebla is offline Trebla  United Kingdom
Clave.
The recommendation for Wima FKP2 at C1 is a good one.
I've always used MKP1837, but i think the Wima in this case is more open sounding.
Old 19th August 2011, 07:45 AM   #535
fmahia is offline fmahia  France
I've also used successfully a Styroflex cap at C1.
Could someone show me a simple transformer output schema for the AK4396 with unbalanced outputs?
I've looked for different solutions but I don't know enough about that to choose the right one.
Old 19th August 2011, 08:56 AM   #536
jeffzen is offline jeffzen
Originally Posted by DirtBag View Post
ok thanks for advice i will use transformer i have but it only has +12v Can I do without opamp stage if im using 32ohm headphones with this DAC? the pcm2704 i have just has a couple of capacitors between output and headphone..
You'll need an output transformer. With such a low load (32 ohms) directly on the DAC's output, it will be definitely damaged.
Old 19th August 2011, 10:32 AM   #537
Reality first!
Thanks Trebla,
I agree, in fact I've tried also MKP1837 and ERO KP1830, both were less good...
Dario
Old 19th August 2011, 01:42 PM   #538
data is offline data  Australia
In the data sheet for the AK4396, it states "When AOUT drives some capacitive load, some resistor should be added in series between AOUT and capacitive load" A capacitive load being either a cap or transformer.
To me this is indicating that being a voltage output DAC like the CS4398, it does require a load (resistor) of some value in series on the analogue outs.
Someone earlier said it does not, well this has been bugging me as I know that the CS4398 requires it and it also is a Differential DAC and a voltage output DAC, in this respect just like the AK4396.
Looking at the suggested circuits in the data sheet, also indicates resistors in series.
If I were doing a transformer output with this chip, I would use resistors in series on the outputs, what value? I'm not sure, but I'm thinking 1.5k for some reason. So using a pair of 600ohm transformers like I have on my DAC I would be looking at 1k resistors on each of the 4 legs in series between the chip and transformers.
But I could be wrong on this figure.
If anyone is thinking of transformers, double check before taking my advise.
Just my thoughts
Old 19th August 2011, 01:47 PM   #539
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
When loaded with a capacitance it needs a series resistor, yes. Loading it with a transformer is slightly another case. I know from experience that CS4397/98 can be loaded directly with transformers with very good results and nothing will break. However, I used 470 Ohm at each output in series to the transformer for current limiting at power-on. I also hoped that it would avoid magnetization because of a possible current at power-on.
It should not be needed as both outputs are at 2,5 V. But I can not guarantee why happens at power-on so I used the resistors.
It's only audio. Member of the non modular PCB design committee
Old 19th August 2011, 01:59 PM   #540
Hah...I'm using 470 ohms on my CS4398 too
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
