DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 6th August 2011, 06:06 PM   #451
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default Final BOM (really?)
You can find attached my final BOM for the MINI2496 DAC.
A note on reading it...
The suggested parts are indicated in bold, under each supplier's row you can find the same part or an alternate one.
But remember the best part is alway the one in bold, the alternates are possibly worse.
The only exceptions are out of production parts, also indicated in bold in the 'Notes' row, such Rikens or Blackgates.
On AK4396 resistors: the right value is 2.4K but PRPs are not available in such value, if you buy alternates remember to buy 2.4K ones...
Enjoy...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 6th August 2011, 07:31 PM   #452
Silver84 is offline Silver84  Denmark
God job :-)
BTW. I think the output level is a little higher than normal. Compared to my cd and dvd player. Is it possible to lower the output level a bit ?
Old 6th August 2011, 07:48 PM   #453
Reality first!
I've cleaned some old stuff...
Dario
Old 7th August 2011, 07:42 AM   #454
jeffzen is offline jeffzen
Hello,
I need your help with some trouble I've run into with my AK4396 DAC.
I use Foobar2000+WASAPI output in Windows 7 x64 to send the music bit-perfectly to the DAC through the digital output of my on-board Realtek ALC892.
If I set the volume level to 100% (to achieve bit-perfect playback) the DAC is clipping. The top and the bottom of the analogue signal is simply missing. Obviously, if I lower the volume to about -5.93 dB (~80%) the clipping stops.
This problem also occurs using Windows mixer's digital output + Windows Media Player.
Is there a problem with the DAC itself, or with the Windows 7 x64's output system?
Thank you for your time and generous help in advance:
Jeff
Old 7th August 2011, 09:39 AM   #455
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
Interesting. I'm 99% sure the problem lies with the computer software.
The output stage of the DAC runs on +/-12 Volts so, with a 2 volt output there is no way the op-amp could be clipping. It must be your software. Try ASIO4ALL instead of wasapi and see if the problem persists. Thinking some more about it, perhaps your realtek driver has a problem? I presume you are using the SPDIF header on your motherboard?
does the DAC clip when you use a DVD/CD player as a SPDIF source?
Old 7th August 2011, 12:22 PM   #456
I am using the S/PDIF header on the motherboard, of course.
However, in the past few hours I've tried out some other setups as well, but the result is always the same: the signal coming from the DAC's output is clipped.
The sources I've tried:
- ALC892 + Windows 7 x64 + WASAPI + foobar2000
- ALC892 + Windows 7 x64 + ASIO + foobar2000
- PCM2902 DIY soundcard + Windows 7 x64 + WASAPI + foobar2000
- ALC892 + Ubuntu 10.10 + ALSA + VLC & Rhythmbox
- Old Thomson DVD player
Here's a link to the test file I've used: 2shared - download 440Hz-15sec-44100Hz-16bit.wav
Jeff
Old 7th August 2011, 07:06 PM   #457
sharpi31 is offline sharpi31  United Kingdom
Just finished my AK4396 kit build. Didn't bother wiring up the -V side of the board as I'm not using the stock opamp output stage. Using Tamura TD-1 output transformers so tapping the balanced signal straight off the AK4396. As I'm using an off-board 12VDC PSU (currently SMPS but SLA battery to follow) I replaced the 7812 with another MC7809CT.
Sounds great so far.
Old 7th August 2011, 07:11 PM   #458
The photos above show the 96K LED (top) illuminating with either a 96K or 88.2K signal. Power LED is centre right, error bottom and no audio centre left.
Old 7th August 2011, 07:25 PM   #459
Looking nice :-)
Do you think the MC78/79xx regulator is a upgrade to the sound ? If yes, in what way then ?
Old 7th August 2011, 07:29 PM   #460
I've read that they have the lowest noise of commonly available 78** regulators, so use them by default, but haven't done a direct comparison with anything else. I suspect the difference to sound quality will be dependant on external factors (how tolerant the components downstream are to noise etc.). Certainly no complaints.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
