DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th April 2011, 01:43 PM   #21
sendler is offline sendler  United States
Default AK4395
I like the AK4395 for it's deeper sound stage and better resolution of ambient detail but it requires 5v digital. The 4396 is a drop in.
Scott
Old 11th April 2011, 07:06 PM   #22
Hello!everybody
I was the designer of this DAC KIT
See everyone in the discussion of this DAC, I'm happy!
I got a lot of new harvest. Thank you!
I am not very good at English.
SO The following text is translated by Google.
First of all thanks to Erin for the recognition of this DAC KIT
The DAC KIT been on the market for some time
Some people prefer AK4395 Because it has better performance More powerful digital filter
I bought some of this specifically to test
This is the new version, but still that PCB
Then I did some testing and listening
I do not know how to describe, because the relationship between language
only SHOW some objective test
In addition, I purchased some AK4396, after the hand will continue to test
RMAA Results
Test by EMU1212M Sound Card
I hope to have some better suggestions so that I can improve these KIT, so that they better listen. Thank you
Old 11th April 2011, 09:44 PM   #23
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Could I ask for a revision of the PCB, to split powersupplies for DAC-chip and other digital circuits. (so a AK4395 could be suplied with 5V, not 3,3V) -now the same 3,3V reg. powers the CS8416, the 74HC04 AND the AK4395.
Arne K
Don't believe everything you think...
Old 12th April 2011, 02:59 AM   #24
HI
The original design has been revised, the ic U5 on board has been replace by 1117-5.the official recommendation for VD of CS8416 is 3.3V, however, I have tested it successfully with supply 5V.
Old 12th April 2011, 03:25 AM   #25
erin is offline erin  Australia
evangelion1999, I would completely omit U7 from the circit, because I do not need to know if there is 96khz or an error. Becuse the music will play or it will not. I allready know what music file I am playing.
Then you would have more room on the board for some extra voltage regulators or dual mono op-amps.
Thanks.
Old 14th April 2011, 12:04 PM   #26
I will give some further comments on this DAC kit.
After about a week of random power cycling and leaving the DAC on, the capacitors (and perhaps the chips???) have all run in very nicely. Dynamics are no longer any issue at all. This DAC punches hard in the bass. There is no sign of digital sound. The AK4393 is very smooth and analog (given the right recording and mastering). One of the reasons I think this kit has the edge over the TDA1541 2.0 DAC from raindrop_hui, is because it has balanced outputs which are summed at the op-amp omitting the need for a DC blocking capacitor which the TDA1541 needs ( in the hui design anyway). You can get some very good DC blocking caps(and cheap too if you experiment) but if you can get away without using one, well this could make all the difference. The speed and detail seems to be increased buy using a DAC without the DC blocking caps. That last bit of detail seems to get through. I was asked in a PM which DAC seems to place instruments better. I have to give it to the AK4393, which seems to do it just a little bit better.
I have to tip my hat to Asahi Kasei for making one heck of a DAC chip, and also to evangelion1999 for making a nice simply designed board available to the masses for such a budget price. I'd say that I have 3/4 optimised this board and it sounds quite wonderful, its on par with my modified TDA1541 2.0 dac, and depending upon what mood I am in, is probably better. I have been long accustomed to the sound of the NOS TDA1541. I will always have a soft spot for the TDA1541, and considering I have not tried the DEM reclocking on my TDA1541, perhaps the TDA1541 has more to give? I suspect it does.
But, for the majority of people this DAC kit will perform well above expectations with a few fairly simple mods, and perhaps, performs at the elite level.
The TDA1541 is a DAC for enthusiasts, the AK4393 is a high performance dac for the people, no frills, no fuss, just pure performance. Highly recommended. Do yourself a favour and buy yourself one today
Old 14th April 2011, 12:25 PM   #27
DIY !
Cobra2's Avatar
Default My version:
I used a few oscons, and replaced a few other caps. Works great!
Arne K
Old 14th April 2011, 12:38 PM   #28
Thank you!
I have some new ideas.
1. increase the equilibrium output
2. using better output structure
3. using LM317 LM337 for the power
4. increase the upsampling(optional)
Old 14th April 2011, 12:44 PM   #29
Arne K
oscons is a good capacitor
I see you used the LM4562 op amp, very good. The op amp I also have two
Old 14th April 2011, 12:47 PM   #30
Originally Posted by evangelion1999 View Post
Thank you!
I am not a fan of upsampling. If you add an upsampling chip, you will increase the cost, and add another chip in the signal, probably decreasing sound quality.
If people want upsampling they can do it with software on the computer.
Your other options are very acceptable in my opinion.
thanks
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
